Hey all,
I’m trying to read a digital pin and if I can, I shall try to adjust some camera settings, on the fly.
I get an OpenMV IDE error trying to setup a button as follows:
button = machine.Pin(9, machine.Pin.IN, machine.Pin.PULL_UP)
TypeError: can’t convert ‘int’ objects to str implicitly.
I’m new to this as you can tell, any help offered, appreciated.
You have to make the PIN number a string.
Thanks, yes I got there by the following…
pin0 = Pin('P9', Pin.IN, Pin.PULL_UP)
pinstate0 = pin0.value()
Now I’m looking for a reference to the other GPIO pins so I can use them as well.
for example…
pin1 = Pin('TIM4_CH1', Pin.IN, Pin.PULL_UP)
gives an error…
Hi, you use the stuff like this:
# PWM Control Example
# This example shows how to do PWM with your OpenMV Cam.
from pyb import Pin, Timer
tim = Timer(4, freq=1000) # Frequency in Hz
# Generate a 1KHz square wave on TIM4 with 50%, 75% and 50% duty cycles on channels 1, 2 and 3 respectively.
ch1 = tim.channel(1, Timer.PWM, pin=Pin("P7"), pulse_width_percent=50)
ch2 = tim.channel(2, Timer.PWM, pin=Pin("P8"), pulse_width_percent=75)
ch3 = tim.channel(3, Timer.PWM, pin=Pin("P9"), pulse_width_percent=50)
while (True):
Thank you.
I found the pin names on the PCB screen-print.
