Pin Example Error
Hey all,
I went to run this example model from this documentation:
http://docs.openmv.io/library/machine.Pin.html?highlight=read%20signal
but when I do I get an error “TypeError: Can’t convert ‘int’ object to str implicitly”
Am I doing something wrong here? I’m trying to read in a 3.3 volt singal from the main board.
Hi, use strings for pin names/numbers ex: “P0”, “P2” etc…
When trying this it still throws the same error.
I tried:
X = Pin(0, Pin.OUT)
No luck =/
Pin(“P0”, …)
That fixed it! Thank you!
