Hello, is there an easy way to stream thermal images using the Flir lipton 3.5 over rtsp, then viewing the streaming images with VLC? Any other methods of streaming the thermal images or suggestions would be helpful. Thanks
Yes, see Examples->RPC-Library->Web-Servers->rtsp_video_server_wlan.py or mjpeg streaming: Examples->OpenMV-Boards->WiFi-Shield->mjpeg_streamer_*.py
Thank you very much!
Hello, I tried RPC library web server and image transfer. The connection is made but there is just a dark image. Any suggestions?
do you see images into the ide?
i cant get picture at all. been trying for days many different variations.
There needs to be more in depth detail how to do this.
i can get it to pick up the AP, but can not stream .
SSID and Key entered one time. is that all that is required? one time entry sssid and key ? What Am I Missing ?
i tried typing in the i.p. the device is on. Tried the ip in the ide example. tried another i.p. No image.
same with bluetooth.
also updated the IDE on a different laptop and can not use it at all now. says something is missing. where is the previous version? hoping the old version will fix it.
Hi, I will respond in the other forum thread you started.
