When using the OPENMV N6 and LCD shield, it was found that the QQVGA2 resolution is not supported and only QVGA can be used. However, using QVGA resulted in the lower half being black because the aspect ratio did not match the LCD resolution. Are there any other available resolutions that can ensure the entire screen covers the LCD completely?
It’s documented now!!! LCD Shield - OpenMV MicroPython 1.28 documentation
Yes, that is incorrect. Will fix!
