I’m trying to send MAVLink v2.0 messages to my Ardupilot using an OpenMV H7 Plus. However, I’m unsure if my code is correct because it’s not working.
P4 = TXD
import image, math, pyb, sensor, struct, time
uart_baudrate = 115200
MAV_system_id = 1
MAV_component_id = 2
lens_mm = 2.8 # Standard Lens.
lens_to_camera_mm = 22 # Standard Lens.
sensor_w_mm = 3.6736 # For OV5640 sensor
sensor_h_mm = 2.7384 # For OV5640 sensor
valid_tag_ids = {2 : 67}
Camera Setup
x_res = 160 # QQVGA
y_res = 120 # QQVGA
f_x = (lens_mm / sensor_w_mm) * x_res
f_y = (lens_mm / sensor_h_mm) * y_res
c_x = x_res / 2
c_y = y_res / 2
h_fov = 2 * math.atan((sensor_w_mm / 2) / lens_mm)
v_fov = 2 * math.atan((sensor_h_mm / 2) / lens_mm)
def translation_to_mm(translation, tag_size): # translation is in decimeters…
return (((translation * 100) * tag_size) / 210)
Link Setup
uart = pyb.UART(3, uart_baudrate, timeout_char = 1000)
Helper Stuff
packet_sequence = 0
def checksum(data, extra): # c_library_v1/checksum.h at master · mavlink/c_library_v1 · GitHub
output = 0xFFFF
for i in range(len(data)):
tmp = data[i] ^ (output & 0xFF)
tmp = (tmp ^ (tmp << 4)) & 0xFF
output = ((output >> 8) ^ (tmp << 8) ^ (tmp << 3) ^ (tmp >> 4)) & 0xFFFF
tmp = extra ^ (output & 0xFF)
return output
MAV_LANDING_TARGET_message_id = 149
MAV_LANDING_TARGET_min_distance = 1/100 # in meters
MAV_LANDING_TARGET_max_distance = 10000/100 # in meters
MAV_LANDING_TARGET_frame = 8 # MAV_FRAME_BODY_NED
MAV_LANDING_TARGET_type = 2 #Landing target represented by a fiducial marker (ex: ARTag)
MAV_LANDING_TARGET_extra_crc = 200
http://mavlink.org/messages/common#LANDING_TARGET
c_library_v2/common/mavlink_msg_landing_target.h at master · mavlink/c_library_v2 · GitHub
def send_landing_target_packet(tag, dist_mm, X, Y, Z, q):
global packet_sequence
temp = struct.pack(“<qfffffbbffffbb”,
0,
0.0,
0.0,
min(max(dist_mm * 0.001, MAV_LANDING_TARGET_min_distance), MAV_LANDING_TARGET_max_distance),
0.0,
0.0,
0,
MAV_LANDING_TARGET_frame,
X,
Y,
Z,
q,
MAV_LANDING_TARGET_type,
1)
temp = struct.pack(“<bbbbbbb30s”,
60,
0,
0,
packet_sequence & 0xFF,
MAV_system_id,
MAV_component_id,
MAV_LANDING_TARGET_message_id,
temp)
temp = struct.pack(“<b35sh”,
0xFE,
temp,
checksum(temp, MAV_LANDING_TARGET_extra_crc))
packet_sequence += 1
uart.write(temp)
LED control
led_success = pyb.LED(2) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
led_fail = pyb.LED(1)
led_counter = 0
def update_led(target_found):
global led_counter
if (target_found) :
led = led_success
led_fail.off()
else :
led = led_fail
led_success.off()
if led_counter % 4 == 0:
led.toggle()
led_counter += 1
Main Loop
tags = sorted(img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y), key = lambda x: x.w() * x.h(), reverse = True)
target_found = False
if tags and (tags[0].id() in valid_tag_ids):
target_found = True
tag_size = valid_tag_ids[tags[0].id()]
dist_mm = math.sqrt(translation_to_mm(tags[0].x_translation(), tag_size) ** 2 + translation_to_mm(tags[0].y_translation(), tag_size) ** 2 + translation_to_mm(tags[0].z_translation(), tag_size) ** 2)
X = tags[0].x_translation()
Y = tags[0].y_translation()
Z = tags[0].z_translation()
q = 1.0
send_landing_target_packet(tags[0], dist_mm, X, Y, Z, q)
img.draw_rectangle(tags[0].rect())
img.draw_cross(tags[0].cx(), tags[0].cy())
print(“Distance %f mm - FPS %f” % (dist_mm, clock.fps()))
print(“FPS %f” % clock.fps())
