hello,
i am using openmv h7 cam to solve a classification problem of captured images, where the caputured image is classified whether it contains a “weevil” insect or not.
so it is a simple binary classification for images.
i retrained imagenetv1_025_128_quant (which is the smallest in size between all the pretrained models) then coverted the graph into tflite by tf_lite_converter.
the output model.tflite is 250kb while the heap memory of the h7 is 240 kb so i get “out of heap memory” error at run time.
i tried tunning every parameter in tf_lite_converter but model size never decreased.
i need help on how can i decrese the model size to fit in the ram?
have you tried another tflite image classification either than the person_detection, and if so what are the procedures you followed?
thanks
side notes to be considered:
1)when i use the mobilenetv1_025_128 without quantization and then quantize it using tf, model is still same size.
2) when i use custom cnn model with smaller layers and weights, accurcy drops alot (so this is not considered)
3) when i follow the official tf lite for microcontroller documentation, the script never complete because this documentation is way too outdated starting from the first command “download_mscoco.sh” (this file is removed from tf repo).
