Don’t know if it is running as it should. I have blob pixels out of the min area rectangle. For me all pixels should be enclosed in the rectangle. And I’m don’t really understand the meaning of
Unlike blob.corners() the min area rectangle corners do not necessarily lie on the blob.
in the blob.min_corners() function description.
Image with a rectangle defined by min_corners():
Code:
import image, time
imgs = image.Image("/stream-c1.pgm",copy_to_fb=True)
imgs.binary([(30,255)])
imgs.open(4)
blob = imgs.find_blobs([(128,255)], merge=True)[0]
imgs.flush()
imgs.draw_edges(blob.min_corners(), color=(128,128,128))
imgs.flush()
Test image in joined stream-c1.zip
I don’t have that behavior with OpenCV with the following code:
import numpy as np
import cv2
img = cv2.imread('stream-c1.pgm',0)
ret, img_thresh = cv2.threshold(img,30,255,cv2.THRESH_BINARY)
kernelsize = 9
kernel = np.ones((kernelsize,kernelsize),np.uint8)
img_open = cv2.morphologyEx(img_thresh, cv2.MORPH_OPEN, kernel)
cnts,hierarchy = cv2.findContours(img_open, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
cnt = cnts[0]
rect = cv2.minAreaRect(cnt)
print(rect)
box = np.int0(cv2.boxPoints(rect))
img = cv2.cvtColor(img, cv2.COLOR_GRAY2BGR)
img_open = cv2.cvtColor(img_open, cv2.COLOR_GRAY2BGR)
img = cv2.drawContours(img, [box], 0, (128,255,128), 1)
img_open = cv2.drawContours(img_open, [box], 0, (128,255,128), 1)
img = cv2.drawContours(img, cnts, -1, (255,128,128), 1)
cv2.imshow('img',img)
cv2.imshow('img_bin',img_open)
cv2.waitKey(0)
cv2.destroyAllWindows()
stream-c1.zip (13.3 KB)
