New user here, I have used Arduinos and Python before, but am just starting in OpenMV with my new Portenta H7 and vision shield. I have taken some code from the examples and put them together into something that scans a QR code with WiFi details formatted like this: ssid-pass::IP to ping (I have not done anything with the IP yet but have a few ideas). I want it to connect to that WiFi network and then get data from the host “google.com” like in the examples. When I run the code, it scans the QR code correctly and gets the WiFi details right, but hangs when actually connecting. I get an “OSError: [Errno 110] ETIMEDOUT”… I am sure the WiFi details are correct and don’t know what the problem might be. Can anyone help me?
The code works the first time I try it then fails the rest of the time after changing nothing
Hardware/software details:
Windows 10
OpenMV IDE 4.1.4-[latest]
Arduino Portenta H7 with ethernet vision shield
USBC-USBC connection
Code:
#WiFi getter and connector
import sensor, image, time, pyb, network, socket
redLED = pyb.LED(1) # built-in red LED
greenLED = pyb.LED(2) # built-in green LED
blueLED = pyb.LED(3) # built-in blue LED
sensor.set_windowing((240, 240)) # look at center 240x240 pixels of the VGA resolution.
sensor.set_auto_gain(False) # must turn this off to prevent image washout...
#while(True):
#clock.tick()
ssid = ""
password = ""
ip = "0.0.0.0"
is_handled = False
while is_handled == False:
for code in img.find_qrcodes():
if (code != None):
img.draw_rectangle(code.rect(), color = 127)
#print(code[4]) # prints URL/payload
print("Payload: " + code.payload()) # also prints URL/payload
# Payload is formatted as ssid-pass::IP
payload = str(code.payload())
#print(payload[0:12])
ssid_pos = payload.find("-")
ssid = payload[0:ssid_pos]
#print(ssid)
pass_pos = ssid_pos + 1
#password = payload[pass_pos:]
ip_pos = payload.find("::") + 2
ip = payload[ip_pos:]
password = payload[pass_pos:ip_pos - 2]
is_handled = True
#print(password)
# commented this out so I could see the debug output
#print(clock.fps())
redLED.on()
greenLED.on()
blueLED.on()
sensor.shutdown(True)
print("SSID:--" + ssid + "--")
print("Password:--" + password + "--")
print("IP to ping:--" + ip + "--")
time.sleep(5)
redLED.off()
greenLED.off()
blueLED.off()
PORT = 80
HOST = "www.google.com"
#HOST = ip
# Init wlan module and connect to network
print("Trying to connect. Note this may take a while...")
wlan.deinit()
wlan.connect(ssid, password, timeout=60000)
# We should have a valid IP now via DHCP
print("WiFi Connected ", wlan.ifconfig())
# Get addr info via DNS
addr = socket.getaddrinfo(HOST, PORT)[0][4]
print(addr)
# Create a new socket and connect to addr
client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
client.connect(addr)
# Set timeout
client.settimeout(3.0)
# Send HTTP request and recv response
client.send("GET / HTTP/1.1\r\nHost: %s\r\n\r\n"%(HOST))
print(client.recv(1024))
# Close socket
client.close()
