Wifi sketch error [CYW43] send_ethernet failed: -16777220
so i every time when i try to conect my arduino h7 portenta vision shield lora. i use the exmple sketch:mjpeg_streamer_py.but when i connect to my iphone’s hotspot it say this error [CYW43] cyw43_kso_set(1): failed
sdio_transfer_cmd53: error=00000004 wr=1 len=64 dma=1 buf_idx=0 STA=00000000 SDMMC=00000000:00000c00 IDMA=00000001
sdio_transfer_cmd53: error=00000004 wr=1 len=128 dma=1 buf_idx=0 STA=00000000 SDMMC=00000000:00000c00 IDMA=00000001
i have try every thing switch cable UFL cannect switxhings etc i dont what to do
Can you provide the script you used? Also, are you running the latest release firmware on your Portena (v4.7.0)?
done look
Please edit your post and use the code tags to format it.
# MJPEG Streaming
# This example shows off how to do MJPEG streaming to a FIREFOX webrowser
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to the IP address/port printed out from ifconfig to view the stream.
import sensor
import socket
SSID = "iPhone 14 van maixent"  # Network SSID
KEY = "********"  # Network key
HOST = ""  # Use first available interface
PORT = 8080  # Arbitrary non-privileged port
# Init sensor
# Init wlan module and connect to network
wlan.connect(SSID, KEY)
    print('Trying to connect to "{:s}"...'.format(SSID))
# We should have a valid IP now via DHCP
print("WiFi Connected ", wlan.ifconfig())
# Create server socket
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, True)
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)
# Set server socket to blocking
s.setblocking(True)
def start_streaming(s):
    print("Waiting for connections..")
    client, addr = s.accept()
    # set client socket timeout to 5s
    client.settimeout(5.0)
    print("Connected to " + addr[0] + ":" + str(addr[1]))
    # Read request from client
    data = client.recv(1024)
    # Should parse client request here
    # Send multipart header
    client.sendall(
        "HTTP/1.1 200 OK\r\n"
        "Server: OpenMV\r\n"
        "Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n"
        "Cache-Control: no-cache\r\n"
        "Pragma: no-cache\r\n\r\n"
    # FPS clock
    # Start streaming images
    # NOTE: Disable IDE preview to increase streaming FPS.
        clock.tick()  # Track elapsed milliseconds between snapshots().
        frame = sensor.snapshot()
        cframe = frame.to_jpeg(quality=35, copy=True)
        header = (
            "\r\n--openmv\r\n"
            "Content-Type: image/jpeg\r\n"
            "Content-Length:" + str(cframe.size()) + "\r\n\r\n"
        client.sendall(header)
        client.sendall(cframe)
        start_streaming(s)
    except OSError as e:
        print("socket error: ", e)
        # sys.print_exception(e)
Hi, it works as expected with my Arduino Portenta H7 and a Lora Vision Shield. Please update your firmware to the latest dev release. See Tools→Install Latest Dev Release.
i try all the things but still not working and i cant find a exmple on arduino ide so what to do now
I’m not sure, if you updated your firmware to the latest and it’s still not working then the hardware may be damaged. All I can say is that isn’t not a firmware bug. So, that just leaves a hardware issue.
Yh thank you I got this new from my birthday but I buy a new one
Or maybe I need to get some 2.4GHz antenna because I use now use a Lora antenna
