Apologies if this is obvious but, is it possible to set up a HOSTNAME on the RT1062? I have several devices and 4need some way of checking which RTSP device to connect to from my client side.
Thank you.
Thank you.
Yes: network — network configuration - OpenMV MicroPython 1.28 documentation
Let me know if it works.
Thank you @kwagyeman , I knew I should have checked the documentation
As always, I appreciate it.
The documentation has historically been bad. By the end of the month it’s going to be the best documentation you’ve ever seen ![]()
