I´m doing a project that I need send photo to google storage or google drive. I choose google storage, because code is much easier than the other one. The problem is, I need a google library that I install in my computer, but my OpenCam can´t find.
I was proving a lot of things but I can´t find the wat. Thank you very much
The code is the next one:
import network, usocket
import ujson as json
import gc
import urequests
from pyb import UART
import sensor, image
import uos
from google.cloud import storage
SSID=‘******’
KEY=‘******’
Connect to WiFi
print(“Connecting to WiFi…”)
wlan = network.WINC()
wlan.connect(SSID, key=KEY)
print(“WiFi Connected!”)
print(wlan.ifconfig())
Capture an image
print(“Capturing image…”)
os.environ[“GOOGLE_APPLICATION_CREDENTIALS”] = ‘your_credentials’
client = storage.Client()
bucket = client.get_bucket(‘your_bucket_name’) #Here goes the bucket name
blob = bucket.blob(‘img’) #The name of the image
blob.upload_from_filename(‘img’)
