Question about a print()
Still nothing :c
I’ll test on my Pi within a week.
Any luck?
I tried it on my Windows laptop with the tests scripts and nothing changed. I still have the suspicion that it might be because of python3 problems.
Sorry, was busy with other things.
I know the scripts works within python2/3 on my windows laptop.
Will test on the Pi.
Thanks!
Then I do not know what is wrong with my part. I am using the rpc tests scripts without modification and I don’t know what else to do.
This is what I’m getting, so it has to be that there is an error when sending the images.
The image result is None, so it cant be on the controller’s side
It’s a sync error with the driver. I’ll check it out. Just finished with an updated TV driver so I can try this out now and see what’s up. It’s probably going to work for me without issue… but, I can relax the timeouts. This might fix it for you.
Ohhhh yikes. Thanks for the help!
Any news?
Hi, I just got done with driver updates. I’m doing documentation now and then I have an IDE release to get out. This is in the back of my mind to help you however.
Please keep bugging me.
Hi, please check your issue on github. I just tested the software on my PC and the Pi. It works fine. However, on the Pi the version of pygame installed will not work directly with my scripts. This PR fixes that:
Anyway, I didn’t see any issues with timeouts. I posted some pictures on my steps.
Thanks! It worked!
I was also wondering if I could buy a better lense for my camera. Just the lense alone. I want to stitch together the images I take, but the algorithms require good enough quality images to process them, and I am not 100% sure if the ones I’m getting are enough.
Yes, you can buy a better lens. That’s the point with it being M12.
Perfect!
I saw the lenses available. Which one provides better image quality?
The lenses do different things. You need to buy one for your application.
