I am hoping to run an object detection model on the OpenMV Cam H7 Plus. I am trying to use SSD mobilenet v2 fpnlite 320. After training this model, it is 11.5 MB as .tflite but by quantizing it I can reduce the size to 3.7 MB. This is smaller than the 4.2 MB available on the heap for the H7 Plus. However, when I try to load the model onto the device I get the error Failed to load model: Failed to allocate tensors. By rebuilding the firmware and using -release_with_logs.a I was able to get the error tflm_backend: Failed to get registration from op code CUSTOM. After looking through some forums, I made sure to quantize using this code:
converter = tf.lite.TFLiteConverter.from_saved_model('path_to_model/saved_model/')
converter.optimizations = [tf.lite.Optimize.DEFAULT]
converter.representative_dataset = representative_data_gen
converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
converter.target_spec.supported_types = [tf.int8]
converter.inference_input_type = tf.uint8
converter.inference_output_type = tf.uint8
tflite_model = converter.convert()
The problem persisted when quantizing this way. I am able to successfully detect objects in test images with the quantized model on my machine. The code I am using to load the model onto the camera is very simple:
import sensor, image, time, os, ml, math, uos, gc
sensor.set_framesize(sensor.HVGA) # Modify as you like.
sensor.set_windowing((320, 320))
sensor.skip_frames(time=2000) # Let the camera adjust.
print(f"Model size = {uos.stat('detect_quant.tflite')[6]}")
print(f"Available space = {gc.mem_free() - (64*1024)}")
net = ml.Model("detect_quant.tflite", load_to_fb=uos.stat('detect_quant.tflite')[6] > (gc.mem_free() - (64*1024)))
print('Successfully loaded model')
except Exception as e:
print('Failed to load model: ' + str(e))
Do you have any idea what the unsupported custom OP might be? Is there anything I can change in the way that I train or quantize the model to make it able to be loaded onto OpenMV Cam H7 Plus?
