Hi, I get expected behavior with no issues with:
# Single Color Grayscale Blob Tracking Example
# This example shows off single color grayscale tracking using the OpenMV Cam.
# Color Tracking Thresholds (Grayscale Min, Grayscale Max)
# The below grayscale threshold is set to only find extremely bright white areas.
thresholds = (245, 255)
sensor.set_framesize(sensor.FHD)
for blob in img.find_blobs([thresholds], pixels_threshold=100, area_threshold=100, merge=True):
if blob.elongation() > 0.5:
img.draw_edges(blob.min_corners(), color=0)
img.draw_line(blob.major_axis_line(), color=0)
img.draw_line(blob.minor_axis_line(), color=0)
img.draw_rectangle(blob.rect(), color=127)
img.draw_cross(blob.cx(), blob.cy(), color=127)
img.draw_keypoints([(blob.cx(), blob.cy(), int(math.degrees(blob.rotation())))], size=40, color=127)
and
img.draw_line(blob.major_axis_line(), color=(0,255,0))
img.draw_line(blob.minor_axis_line(), color=(0,0,255))
