OpenMV RT1062 - Wifi Connectivity
Im using the example of streaming a mpeg using a WIFI
But when trying to connect to the WiFi Network it doesnt connect.
It has been connected for several times, and when it does the connection is really good.
The signal of my wifi is strong, and when trying to search it using the scan example it finds it.
# MJPEG Streaming
# This example shows off how to do MJPEG streaming to a FIREFOX webrowser
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to the IP address/port printed out from ifconfig to view the stream.
import sensor
import socket
SSID = "mywifi"  # Network SSID
KEY = "12345678"  # Network key
HOST = ""  # Use first available interface
PORT = 8080  # Arbitrary non-privileged port
# Init sensor
# Init wlan module and connect to network
wlan.connect(SSID, KEY)
    print('Trying to connect to "{:s}"...'.format(SSID))
# We should have a valid IP now via DHCP
print("WiFi Connected ", wlan.ifconfig())
# Create server socket
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, True)
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)
# Set server socket to blocking
s.setblocking(True)
def start_streaming(s):
    print("Waiting for connections..")
    client, addr = s.accept()
    # set client socket timeout to 5s
    client.settimeout(5.0)
    print("Connected to " + addr[0] + ":" + str(addr[1]))
    # Read request from client
    data = client.recv(1024)
    # Should parse client request here
    # Send multipart header
    client.sendall(
        "HTTP/1.1 200 OK\r\n"
        "Server: OpenMV\r\n"
        "Content-Type: multipart/x-mixed-replace;boundary=openmv\r\n"
        "Cache-Control: no-cache\r\n"
        "Pragma: no-cache\r\n\r\n"
    # FPS clock
    # Start streaming images
    # NOTE: Disable IDE preview to increase streaming FPS.
        clock.tick()  # Track elapsed milliseconds between snapshots().
        frame = sensor.snapshot()
        cframe = frame.to_jpeg(quality=35, copy=True)
        header = (
            "\r\n--openmv\r\n"
            "Content-Type: image/jpeg\r\n"
            "Content-Length:" + str(cframe.size()) + "\r\n\r\n"
        client.sendall(header)
        client.sendall(cframe)
        start_streaming(s)
    except OSError as e:
        print("socket error: ", e)
        # sys.print_exception(e)
Tried also the following but didnt work
wlan.active(False)
wlan.config(ssid=SSID, key=KEY, channel=2)
Hi, So, it connects sometimes and then doesn’t connect other times?
Yes, That right.
I have tried to connect for the first time. its has been connected quiet fast.
Then when running the same example again. he tries to connect with out any success.
I need to mention, that happens with several WiFi networks including my phone Hotspot.
Hi, I just tried with my RT1062 using the latest firmware release and I’m able to start and stop the script, start and stop the browser connected, and back and forth and it works without issues.
Not sure how to help debug…
