OpenMV Cam H7 SD card size, 32 or 64GB?
What is the maximum size of the OpenMV Cam H7 SD card, is it 32GB or 64GB?
The datasheet https://cdn.shopify.com/s/files/1/0803/9211/files/OpenMV-H7.pdf says 64GB, but the pinout image https://cdn.shopify.com/s/files/1/0803/9211/files/cam-v4-pinout.png on the kickstarter page says 32GB and hardware setup 3. Hardware Setup — MicroPython 1.15 documentation says 32GB.
thanks,
Chris
64GBs cards work, but you should format it as exFAT it’s much faster for large SD cards.
