Open MV IDE Error: No device found on COM4
I don’t have much experience in Arduino or Open MV, so any detailed help on the below would be much appreciated.
I’m trying to use MicroPython on my Arduino Nano 33 BLE Sense for educational purposes, I need to transform a Python code that deploys a Neural Network on my Arduino device, after lots of searching I was led to Open MV as a path to my goal.
This is the first link I followed for reference: MicroPython - Python for microcontrollers
This is the second link:
While following the second link, I did all the steps but when I click on the “connect” symbol at the bottom of the left toolbar and choose "Install the latest release firmware (v4.4.3) and click ok (with erase internal file system unticked) I get the following error:
BOSSAC firmware update failed!
C:/Program Files/OpenMV IDE/share/qtcreator/bossac/windows/bossac.exe -e -w --offset=0x16000 --port=COM4 -i -d -U -R C:\Users\User\AppData\Roaming\OpenMV\openmvide\firmware\arduino_nano_33_ble_sense\firmware.bin
I can’t get past this error, please let me know what I can do to fix this.
Please note that I am 100% sure that the device is connected to COM 4 (I checked this from the device manager) and that the orange light is blinking which means that the device is in bootloader mode.
Thank you in advance!
Hi, you need to install the right bootloader on your device from the Arduino IDE. Otherwise it will just loop over and over again and stay in the Arduino firmware.
Thank you for taking the time to reply.
As I mentioned, I did follow all the steps from this link:
https://docs.arduino.cc/tutorials/nano-33-ble/getting-started-omv
I followed step by step making sure I’m not doing anything wrong, I installed the mbed nano library and ran the example and uploaded it to the device. I was asked to click Y/N twice, once for the bootloader and once for the soft thing (I don’t remember exactly), I clicked Y twice and waited for the device to restart, it did restart into bootloader and I made sure that it did and yet I’m still getting this error.
Unless you’re referring to some other step that’s not found in the link? If that’s the case please let me know how I can do that.
Thank you,
Ah, reading more, it looks like this is an issue on our IDE end:
"BOSSAC firmware update failed!
No device found on COM4"
This means BOSSAC wasn’t able to flash anything. This is unrelated to the bootloader.
Okay, I would just run that command like in a terminal and this should flash the board. There may be a timing issue with the IDE were we kicked off the program before your board was in bootloader mode that is causing the issue.
Just copy this into a terminal while the board is in bootloader mode and it should be flashed:
Excuse my ignorance, by terminal you mean a new file inside OpenMV IDE right?
I pasted this command in a new file but the run button (arrow) is greyed out for me (I believe this is because it’s not connected to the device). So I’m unable to connect the device but I’m also unable to run this command because the device is not connected, am I missing anything here?
P.S I tried running the command in a command prompt just in cade that’s what you meant but I got the error C\Program is not a recognized command.
I have no experience in this whatsoever so please bare with me here, thanks.
I gave it one last try and it installed properly! Not sure if you did something on your end but I was finally able to finish this step and the arrow is green now, thank you!! I will move on with the next steps now.
Yeah, it’s just a race condition on timing. The IDE doesn’t know when it’s allowed to launch the command. So, it just waits a second and then tried. If the device hasn’t attached by then it fails.
When you get those errors in a command prompt is because windows thinks the \ is an escape sequence and ignores the next char. You have to flip them to /.
Understood, thank you.
I have one more question (if you have the time to help I would really appreciate it):
This is my first time working with Arduino and OpenMV, my goal is to transform a Python code that I wrote on Spyder app into a code that can be deployed on Arduino using OpenMV and MicroPython. My code trains a neural network to check a data set of numbers and see if each number in the data set is < 800 then it returns 1 and if it’s >= 800 it returns 0, and if it’s 0 the red LED should blink.
My final goal is to use the MQ-135 (Gaz Sensor) to return values for me (from the sensor measurements) instead of having to give it a data set. Then the code will check the RETURNED values from the sensor and return 1 or 0 based on these numbers. I tried pasting the Python code as is into Open MV (I now know this doesn’t work) but I have no idea how to move forward. Is there a simple way to transform the Python code I have so that Open MV can deploy it into Arduino? Note: Using neural network is a MUST in my case.
This is my code:
import pandas as pd
import numpy as np
import tensorflow as tf
from tensorflow import keras
from tensorflow.keras.optimizers.schedules import ExponentialDecay
from sklearn.model_selection import train_test_split
from sklearn.preprocessing import MinMaxScaler
import matplotlib.pyplot as plt
from keras.callbacks import EarlyStopping, LearningRateScheduler
# Set the random seed for reproducibility
tf.random.set_seed(42)
# Load your dataset (replace 'your_dataset.csv' with the actual file name)
df = pd.read_csv('C:\\Users\\Malak\\co2_2000_dataset.csv')
# Split the dataset into features (X) and target variable (y)
X = df[['CO2']].values  # Features
y = df['Label'].values  # Target variable
# Split the data into training and test sets (adjust test_size as needed)
X_train, X_test, y_train, y_test = train_test_split(X, y, test_size=0.2, random_state=42)
# Normalize feature values to a range between 0 and 1
scaler = MinMaxScaler()
X_train = scaler.fit_transform(X_train)
X_test = scaler.transform(X_test)
np.save('X_CO2train.npy', X_train)
np.save('X_CO2test.npy', X_test)
np.save('y_CO2train.npy', y_train)
np.save('y_CO2test.npy', y_test)
# Load the preprocessed training and test sets
X_train = np.load('X_CO2train.npy')
X_test = np.load('X_CO2test.npy')
y_train = np.load('y_CO2train.npy')
y_test = np.load('y_CO2test.npy')
test_dataset = tf.data.Dataset.from_tensor_slices((X_test, y_test))
# Create a sequential model with two hidden layers
initial_learning_rate = 0.01
lr_schedule = ExponentialDecay(
    initial_learning_rate, decay_steps=100, decay_rate=0.9, staircase=True
model1 = keras.Sequential([
    keras.layers.Dense(5, activation='relu', input_shape=[1]),
    keras.layers.Dense(3, activation='relu'),
    keras.layers.Dense(1, activation='sigmoid')
# Compile the model with the learning rate schedule
model1.compile(optimizer=tf.keras.optimizers.Adam(learning_rate=lr_schedule),
              loss='binary_crossentropy',
              metrics=['accuracy'])
# Print model summary
model1.summary()
initial_weights = model1.layers[0].get_weights()
# Print the initial weights and biases
print("Initial Weights:", initial_weights[0])
print("Initial Biases:", initial_weights[1])
start_time = time.time()
# Train the model
history = model1.fit(X_train, y_train, epochs=100, batch_size=32, validation_split=0.1)
# Evaluate the model on the test set
test_loss, test_accuracy = model1.evaluate(X_test, y_test)
print(f'Test accuracy: {test_accuracy*100:.2f}%')
# Make predictions on the test set
y_pred = (model1.predict(X_test) > 0.5).astype(int)
training_time = time.time() - start_time
# Print the training time
print(f"Training time for neural network with three hidden layers: {training_time} seconds")
final_step = 100  # Adjust this to the final step of your training
# For model1
final_learning_rate_model1 = lr_schedule(final_step)
print(f"Final Learning Rate for model1: {final_learning_rate_model1}")
# Define a function to load the test set as a representative dataset
def representative_data_gen():
    for input_data in X_test:
        # Ensure input_data is of data type FLOAT32
        input_data = input_data.astype(np.float32)
        yield [input_data]
# Extract the training and validation accuracy and loss from the history object
train_accuracy = history.history['accuracy']
val_accuracy = history.history['val_accuracy']
train_loss = history.history['loss']
val_loss = history.history['val_loss']
# Create subplots for accuracy and loss
plt.figure(figsize=(12, 4))
# Plot training & validation accuracy values
plt.subplot(1, 2, 1)
plt.plot(train_accuracy, label='Training Accuracy')
plt.plot(val_accuracy, label='Validation Accuracy')
plt.title('Model Accuracy')
plt.xlabel('Epoch')
plt.ylabel('Accuracy')
plt.legend()
# Plot training & validation loss values
plt.subplot(1, 2, 2)
plt.plot(train_loss, label='Training Loss')
plt.plot(val_loss, label='Validation Loss')
plt.title('Model Loss')
plt.xlabel('Epoch')
plt.ylabel('Loss')
plt.legend()
# Show the plots
plt.tight_layout()
plt.show()
# Make predictions on the test set and save it to a CSV file
test_set_with_labels = pd.DataFrame({'CO2': X_test.flatten(), 'Label': y_test, 'Predicted_Label': y_pred.flatten()})
# Define the converter with quantization
converter = tf.lite.TFLiteConverter.from_keras_model(model1)
# Set the optimization flag to enable quantization
converter.optimizations = [tf.lite.Optimize.DEFAULT]
converter.representative_dataset = representative_data_gen
# Optionally, you can specify the target quantization precision for the weights and activations
converter.target_spec.supported_ops = [tf.lite.OpsSet.TFLITE_BUILTINS_INT8]
converter.inference_input_type = tf.int8
converter.inference_output_type = tf.int8
# Convert the model to TFLite format
tflite_quantized_model = converter.convert()
# Save the quantized TFLite model to a file
with open('quantized_model.tflite', 'wb') as f:
    f.write(tflite_quantized_model)
# Get and print the current working directory
current_directory = os.getcwd()
print("path:", current_directory)
import numpy as np
# Load the TFLite model
with open('quantized_model.tflite', 'rb') as f:
    tflite_model = f.read()
# Convert the model bytes to a C array format
model_data = ', '.join(map(str, tflite_model))
# Write the C array to a header file
with open('model_data.h', 'w') as f:
    f.write('#ifndef MODEL_DATA_H\n')
    f.write('#define MODEL_DATA_H\n\n')
    f.write('const unsigned char model_data[] = {' + model_data + '};\n\n')
    f.write('#endif\n')
Thank you for your time.
Hi, please read Edge Impulse’s documentation on OpenMV. You can convert your model there. We do not run desktop python code.
Once you have a .tflite model you can run that on the OpenMV Cam. As long as you are using ops we support it should run. That said, we are optimized for vision… if you are doing something for a linear 1d dataset I don’t think we have anything for you.
