We used to run 2 Edge impulse datasets with a steady 8 FPS, since we updated to the newest version on the Cam and IDE we only got 4 FPS. What could possibly cause this problem?
(We also tried the standard hello script, which before the update we got a FPS of around 175 we now only get 100 FPS using the global shutter)
After we found out this was causing us problem, we decided to test the regular H7 plus without global shutter giving us the same issue, since the update the hello script only runs at 23 FPS instead of the 50 when we used it a while ago.
