Thanks, I did try that earlier but over indented ever so slightly and kept getting errors, hence the handle, lol
Here is my working code, it works very well for testing right now, does anyone have any suggestions how I can make it better/faster? Like I said, working great, interested in hearing how I could improve it.
if blob.elongation() > 0.5:
#img.draw_rectangle(blob.rect())
x = blob.cx()
y = blob.cy()
#Copy of Arduino map function
def map(x, in_min, in_max, out_min, out_max):
return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
xAxis= map(x,0,300, -15, 15)
yAxis= map(y,0,240,15,-15)
print(xAxis, ",", yAxis)
