Many years ago I was really intrigued and shocked by the global shutter’s capacity to track NIR beacons really really far away. It provides a much more consistent frame-to-frame blob than the higher resolution OV5640 which is really helpful in certain processing and filtering approaches.
However, there’s one aspect I didn’t fully understand that I always wondered about. Is there a sort of “binning” of 4 pixels applied when the readout window is set? In my tests, and even in the video below, the output centroid of tracked blobs is within multiples of pixels. What may be detected as 16-25 pixels in size for the whole window may turn out to be 1 - 4 pixels when displaying that small readout window at the same exposure.
I am using the 4.3.3 firmware version from a few years ago on an H7 + right now since that’s the only one that works with the example to my understanding.
Here is the code and link to the exact firmware bin I am using if you would like to replicate this quirk. If anyone remembers or has seen this happen before, Im curious to hear why it happens and if it’s mitigatable to get more pixels triggered by incident light. I would really like to try this again on the upcoming N6 with its super crazy resolution 1MP global shutter soon : D
Sep 4, 2022 - 4.3.3
-the mt9v SET_READOUT_WINDOW only works with this older build, otherwise sensor.control failed
-Using a ribbon cable and the MT9V034 mod R1 with a white connector. The code can be tested against a bright phone light.
USAGE:
In the serial Terminal, ctrlF for bigBINGO returns the blob size when using the standard WVGA2 readout resolution. Notice how its a big 3036 ish sum.
EVIDENCE:
I have a hunch that the pixels are sampled 1 in every 4 or something as the square root of 3036, then divided by four, and then squared again yields 189 exactly! It’s tricky to defocus my long range beacon tracking optics to account for a 4x resolution drop making up for it with PSF, but, is there a way people handle this to get the full readout resolution using a global shutter?
Slightly modified 100fps IR tracking example script below for exposure and blob sizes per resolution. Feel free to ctrl F smallbingo and bigbingo to compare the two readout modes. I would really love to try this on the upcoming N6 but maybe I was using the readout window wrong all along. The OpenMV is such a cool platform compared to the raspberry pi 2, 4, and jetson nano back in 2021. Thanks for your time.
This work is licensed under the MIT license.
Copyright (c) 2013-2023 OpenMV LLC. All rights reserved.
https://github.com/openmv/openmv/blob/master/LICENSE
This example shows off how to use readout window control to readout a small part of a camera
sensor pixel array at a very high speed and move that readout window around.
This example is was designed and tested on the OpenMV Cam H7 Plus using the OV5640 sensor.
import sensor
EXPOSURE_MICROSECONDS = 250
TRACKING_THRESHOLDS = [(128, 255)] # When you lower the exposure you darken everything.
SEARCHING_RESOLUTION = sensor.WVGA2 #FOR mt9v034 full photos
SEARCHING_AREA_THRESHOLD = 16
SEARCHING_PIXEL_THRESHOLD = SEARCHING_AREA_THRESHOLD
TRACKING_RESOLUTION = sensor.QQQVGA #For super crazy high speed tracking
TRACKING_AREA_THRESHOLD = 16
TRACKING_PIXEL_THRESHOLD = TRACKING_AREA_THRESHOLD
TRACKING_EDGE_TOLERANCE = 0.05 # Blob can move 5% away from the center.
sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to GRAYSCALE
sensor.set_framesize(SEARCHING_RESOLUTION)
sensor.skip_frames(time=1000) # Wait for settings take effect.
sensor.set_auto_gain(False) # Turn off as it will oscillate.
sensor.set_auto_exposure(False, exposure_us=EXPOSURE_MICROSECONDS)
sensor_w and sensor_h are the image sensor raw pixels w/h (x/y are 0 initially).
x, y, sensor_w, sensor_h = sensor.ioctl(sensor.IOCTL_GET_READOUT_WINDOW)
# We need to find an IR object to track - it's likely to be really bright.
blobs = img.find_blobs(
TRACKING_THRESHOLDS,
area_threshold=SEARCHING_AREA_THRESHOLD,
pixels_threshold=SEARCHING_PIXEL_THRESHOLD,
if len(blobs):
most_dense_blob = max(blobs, key=lambda x: x.density())
print(most_dense_blob.cyf()," ", most_dense_blob.pixels(), " bigbingo")
img.draw_rectangle(most_dense_blob.rect())
def get_mapped_centroid(b):
# By default the readout window is set the whole sensor pixel array with x/y==0.
# The resolution you see if produced by taking pixels from the readout window on
# the camera. The x/y location is relative to the sensor center.
x, y, w, h = sensor.ioctl(sensor.IOCTL_GET_READOUT_WINDOW)
# The camera driver will try to scale to fit whatever resolution you pass to max
# width/height that fit on the sensor while keeping the aspect ratio.
ratio = min(w / float(sensor.width()), h / float(sensor.height()))
# Reference cx() to the center of the viewport and then scale to the readout.
mapped_cx = (b.cx() - (sensor.width() / 2.0)) * ratio
# Since we are keeping the aspect ratio there might be an offset in x.
mapped_cx += (w - (sensor.width() * ratio)) / 2.0
# Add in our displacement from the sensor center
mapped_cx += x + (sensor_w / 2.0)
# Reference cy() to the center of the viewport and then scale to the readout.
mapped_cy = (b.cy() - (sensor.height() / 2.0)) * ratio
# Since we are keeping the aspect ratio there might be an offset in y.
mapped_cy += (h - (sensor.height() * ratio)) / 2.0
mapped_cy += y + (sensor_h / 2.0)
return (mapped_cx, mapped_cy) # X/Y location on the sensor array.
def center_on_blob(b, res):
mapped_cx, mapped_cy = get_mapped_centroid(b)
# Switch to the res (if res was unchanged this does nothing).
sensor.set_framesize(res)
# Construct readout window. x/y are offsets from the center.
x = int(mapped_cx - (sensor_w / 2.0))
y = int(mapped_cy - (sensor_h / 2.0))
w = sensor.width()
h = sensor.height()
# Focus on the centroid.
sensor.ioctl(sensor.IOCTL_SET_READOUT_WINDOW, (x, y, w, h))
# See if we are hitting the edge.
new_x, new_y, w, h = sensor.ioctl(sensor.IOCTL_GET_READOUT_WINDOW)
# You can use these error values to drive servos to move the camera if you want.
x_error = x - new_x
y_error = y - new_y
if x_error < 0:
print("-X Limit Reached ", end="")
if x_error > 0:
print("+X Limit Reached ", end="")
if y_error < 0:
print("-Y Limit Reached ", end="")
if y_error > 0:
print("+Y Limit Reached ", end="")
center_on_blob(most_dense_blob, TRACKING_RESOLUTION)
# This loop will track the blob at a much higher readout speed and lower resolution.
# Find the blob in the lower resolution image.
area_threshold=TRACKING_AREA_THRESHOLD,
pixels_threshold=TRACKING_PIXEL_THRESHOLD,
# If we loose the blob then we need to find a new one.
if not len(blobs):
# Reset resolution.
sensor.ioctl(sensor.IOCTL_SET_READOUT_WINDOW, (sensor_w, sensor_h))
break
# Narrow down the blob list and highlight the blob.
print(
clock.fps(), "BLOB cx:%d, cy:%d" % get_mapped_centroid(most_dense_blob), most_dense_blob.pixels(), " smallbingo"
x_diff = most_dense_blob.cx() - (sensor.width() / 2.0)
y_diff = most_dense_blob.cy() - (sensor.height() / 2.0)
w_threshold = (sensor.width() / 2.0) * TRACKING_EDGE_TOLERANCE
h_threshold = (sensor.height() / 2.0) * TRACKING_EDGE_TOLERANCE
# Re-center on the blob if it starts going out of view (costs FPS).
if abs(x_diff) > w_threshold or abs(y_diff) > h_threshold:
