# Hello World Example
import sensor, image, time
import gc
sensor.set_framesize(sensor.QQQVGA) # Set frame size to QVGA (320x240)
width=sensor.width()
height=sensor.height()
def scale_img3(img):
img_scaled=image.Image(img.width()*3,img.height()*3,sensor.GRAYSCALE)
for r in range(0,img.height()):
for c in range(0,img.width()):
color=img.get_pixel(c,r)
img_scaled.set_pixel(c*3,r*3,color)
img_scaled.set_pixel(c*3+1,r*3,color)
img_scaled.set_pixel(c*3+2,r*3,color)
img_scaled.set_pixel(c*3,r*3+1,color)
img_scaled.set_pixel(c*3+1,r*3+1,color)
img_scaled.set_pixel(c*3+2,r*3+1,color)
img_scaled.set_pixel(c*3,r*3+2,color)
img_scaled.set_pixel(c*3+1,r*3+2,color)
img_scaled.set_pixel(c*3+2,r*3+2,color)
return img_scaled
def read_image(img):
""" blob_dict={color: [[pixels],[pixels]]"""
height=img.height()
width=img.width()
global blob_dict
for r in range(height-1):
for c in range(width-1):
top_left=img.get_pixel(c,r)
top_right=img.get_pixel(c+1,r)
bottom_right=img.get_pixel(c+1,r+1)
bottom_left=img.get_pixel(c,r+1)
if top_left!=top_right: # left ro right
if top_left in blob_dict:
blob_dict[top_left].add(r*width+c)
blob_dict[top_left]=set()
if top_right in blob_dict:
blob_dict[top_right].add(r*width+c+1)
blob_dict[top_right]=set()
if top_left!=bottom_left: # top to bottom
if bottom_left in blob_dict:
blob_dict[bottom_left].add((r+1)*width+c)
blob_dict[bottom_left]=set()
if top_left!=bottom_right: # diagonal
if bottom_right in blob_dict:
blob_dict[bottom_right].add((r+1)*width+c+1)
blob_dict[bottom_right]=set()
if bottom_left!=top_right: # diagonal
for c,blobs in blob_dict.items():
blob_dict[c]=list(blobs)
#print("unsorted dict created.")
blob_dict={}
img_cond=scale_img3(img)
read_image(img_cond)
shape=[img.height(),img.width()]
print("len(blob_dict)=",len(blob_dict),"fps:",clock.fps())
blob_dict.clear()
I am trying to run the above code and i get MemoryError on QQQVGA and above. Is there anything that i can do to fix the error?
