Oh, I was talking about cutting the image horizontally into three pieces. Like a top piece, a middle piece, and a bottom piece. I think you need to do that because the camera perspective is going to skew lines that are far off. Like, think about how far away the part of the line that is near the top of the image from the bottom part of the image. I don’t think you can tread them as one thing and get good results.
Ok, I think I fixed that logic problem. I need to keep the “If lines” conditional to trap cases where no lines are found and we can’t calculate a slope. But you were right that I had the flow wrong. I think this commit fixes it:
Okay… other thoughts… I’d work on your activation function:
steer_angle = 1/(totalslope/counter)
Maybe try to determine the angle from thinking about the slope as if it were the slop of the hypotenuse on a right triangle and you’re trying to find an angle? Not exactly sure what the math should be.
Normally you’d use an inv tangent function there, but given the distortion effect in slope between the line close to you and that far away, I’m thinking of just implementing a regular PID and see if I can tune the distortion away with damping functions.
Still, we’re making some progress. Now it weaves its way drunkenly through the track, but at least stays on the track.
This code with the new M7 OpenMV cam did great this weekend at the Thunderhill Self Racing Cars/DIY Robocars race (Login to Meetup | Meetup). Came in 2nd, beating out nVidia TX2 cars and a lot of RaspberryPi 3s. Here’s a practice lap:
The secret to the good performance was weighting the top third of the frame the highest. These were the ROIs that worked best for us:
ROIS = [ # [ROI, weight]
(0, 100, 160, 20, 0.1), # You’ll need to tweak the weights for your app
(0, 050, 160, 20, 0.3), # depending on how your robot is setup.
(0, 000, 160, 20, 0.7)
Like a druken sailor. You’re definitely pushing the PID loop out of it’s control zone. But, hey, it still works. If you went slower I bet you could lock perfectly on the line.
Hello Zlite I am working on this project with my uncle who is Trevor we been tackling this for a while this was our version 1.0 I know he has revised it but this code does follow the line well. I can help you out a bit to if you let me know what your issues are in the coding, I sense it can be little confusing for some people I code a lot and it was even little tricky for me. But I am more then willing to help as well. https://github.com/E-V-G-N/OpenMV-Line-Follower/blob/master/Line%20Following%20V%201.0
Yeah, we were going to go that route, but we decided to not for some reason. We are focusing on more like you were how to get it to lock onto the line. We are looking into adding a little headlight to help with the contrast and shadow issues. I just got the new board so I am going to take a look at your code and see what I can tweak for me and my uncle’s application a bit.
Hey did something happen when the new cameras came out? We had a fully functional code and now gettings lots of undefined errors and what not. here is a view of the code
The find blobs API was updated a while back. That code needs to be tweaked for the new Find blobs method. Only minor changes are necessary to the script.
See the line following example code. That was updated with how the new find blobs script accepts arguments.
# Tracks a black line. Use [(128, 255)] for a tracking a white line.
GRAYSCALE_THRESHOLD = [(0, 64)]
sl = Servo(2) # P8
sr = Servo(1) # P7
# Camera setup...
sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.
sensor.skip_frames(30) # Let new settings take affect.
def linerobot(turnangle, turnvelocity):
wheelwidth = 6
turnradius = wheelwidth/(math.sqrt(2 - 2 * math.cos(math.radians(turnangle)))+.0000001)
if turnangle <= 0:
vl = turnvelocity / turnradius * ( turnradius - wheelwidth / 2)
vr = turnvelocity / turnradius * ( turnradius + wheelwidth / 2)
sl.speed(vl)
sr.speed(-vr)
vl = turnvelocity / turnradius * ( turnradius + wheelwidth / 2)
vr = turnvelocity / turnradius * ( turnradius - wheelwidth / 2)
sl.speed(vl)
sr.speed(-vr)
def check_stop():
stopROI = [(0, 000, 160,20)]
blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True) # r[0:4] is roi tuple.
merged_blobs = img.find_markers(blobs)
if blobs:
# Find the index of the blob with the most pixels.
most_pixels = 0
largest_blob = 0
for i in range(len(merged_blobs)):
if merged_blobs[i].pixels() > most_pixels:
most_pixels = merged_blobs[i].pixels()
largest_blob = i
if merged_blobs[largest_blob][2] > 80:
# Draw a rect around the blob.
img.draw_rectangle(merged_blobs[largest_blob][0:4]) # rect
img.draw_cross(merged_blobs[largest_blob][5], # cx
merged_blobs[largest_blob][6]) # cy
sl.speed(0)
sr.speed(0)
print("false")
return True
img.draw_rectangle(blobs[largest_blob].rect())
img.draw_cross(blobs[largest_blob].cx(),
blobs[largest_blob].cy())
# Each roi is (x, y, w, h). The line detection algorithm will try to find the
# centroid of the largest blob in each roi. The x position of the centroids
# will then be averaged with different weights where the most weight is assigned
# to the roi near the bottom of the image and less to the next roi and so on.
(0, 100, 160, 20, 0.7), # You'll need to tweak the weights for you app
(0, 000, 160, 20, 0.1)
# Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
weight_sum = 0
for r in ROIS: weight_sum += r[4] # r[4] is the roi weight.
centroid_sum += blobs[largest_blob].cx() * r[4] # r[4] is the roi weight.
center_pos = (centroid_sum / weight_sum) # Determine center of line.
print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
# connected to your computer. The FPS should increase once disconnected.
