Hello. I’m using OpenMV H7 Plus board with Arduino Mega 2560.
For my project I’m using library for OpenMV (openrv/homography/README.md at master · nickoala/openrv · GitHub). I put files on my camera’s SD-card like this:
Mode LastWriteTime Length Name
d----- 23.05.2025 15:16 rv
d----- 23.05.2025 15:16 vec
-a---- 01.01.2015 0:00 0 .openmv_disk
-a---- 24.03.2025 11:49 1904 mtx.py
-a---- 09.10.2025 14:30 171 main.py
My problem is that when I launch my script via OpenMV IDE - everything is great - I get messages with data on my mega and everything works. When I try to start this whole project automaticly - not via IDE but just with power source and UART connection between Mega and OpenMV - I dont get any data at all on my Arduino - unless I firstly start camera script via IDE - then unplug it cable from my computer and then it continues working and my Arduino gets data.
I probably should mention that other code like simple “Hello World!” passing from camera to arduino works perfectly, and the cable was tested - it’s not faulty. And the UART connection is correct. The problem is probably in libaries, it feels like my main.py file can’t open files in rv lib?
Can anyone help with this problem?
My code for OpenMV:
import sensor, utime
from pyb import UART
from rv.planar import Planar
sensor.set_auto_gain(False, gain_db=22.6067)
sensor.set_auto_whitebal(False, rgb_gain_db=(64.3917, 60.206, 62.8227))
sensor.set_auto_exposure(False, exposure_us=12000)
sensor.skip_frames(time=500)
thresholds = [(61, 94, -39, -9, -2, 39)]
uart = UART(1, 19200, timeout_char=200)
H = [[-3.53512728e-02, -1.71368433e+00, 3.98107181e+02],
[ 1.72228029e+00, -3.30469606e-02, -2.69140391e+02],
[ 1.20710983e-04, -1.79347218e-04, 1.00000000e+00]]
offset = [-100, 10]
img = sensor.snapshot() .lens_corr(1.2) # .rotation_corr(x_rotation = -25)
p = Planar(H, offset)
blobs = img.find_blobs(thresholds, pixels_threshold=150, area_threshold=150)
if len(blobs) > 0:
blob = blobs[0]
coordinates = [[blob.cx(), blob.cy()]]
result = p.project(coordinates)[0]
print(f"x = {result[1]}, y = {result[0]}")
uart.write("{} {}\n".format(result[1], result[0]))
utime.sleep_ms(100)
Code for testing if Arduino gets any data:
void setup() {
// put your setup code here, to run once:
Serial.begin(19200);
Serial3.begin(19200);
void loop() {
// put your main code here, to run repeatedly:
if (Serial3.available()) {
// Read the most recent byte
byte byteRead = Serial3.read();
// ECHO the value that was read
Serial.write(byteRead);
