I encountered a problem. When I used the lenet.network file I created, it could not effectively realize the number recognition. Instead, it kept returning 0 tags and 50 possibilities. Below is my network structure:
layer {
type: "Data"
top: "data"
top: "label"
include {
phase: TRAIN
transform_param {
scale: 0.00390625
data_param {
source: "D:/caffe/caffe-master/examples/mnist/lmdb/train_lmdb"
batch_size: 64
backend: LMDB
layer {
type: "Data"
top: "data"
top: "label"
include {
phase: TEST
transform_param {
scale: 0.00390625
data_param {
source: "D:/caffe/caffe-master/examples/mnist/lmdb/test_lmdb"
batch_size: 100
backend: LMDB
layer {
type: "Convolution"
bottom: "data"
top: "conv1"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 20
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv1"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2"
param {
lr_mult: 1
param {
lr_mult: 2
convolution_param {
num_output: 10
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "Pooling"
bottom: "conv2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "InnerProduct"
bottom: "pool2"
top: "ip1"
param {
lr_mult: 1
param {
lr_mult: 2
inner_product_param {
num_output: 500
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "ip1"
top: "ip1"
layer {
type: "Accuracy"
bottom: "ip1"
bottom: "label"
top: "accuracy"
include {
phase: TEST
layer {
type: "SoftmaxWithLoss"
bottom: "ip1"
bottom: "label"
top: "loss"
The file has been effectively generated with a size of 80kb, but it cannot be used due to the above reasons. PS: The lenet.network file of the routine is now available.thx
