Large display / screen
Hello
What are the possibilities of connecting a larger display (e.g. 10 ‘’).
We will be working on support for 24-bit LCD support in our firmware base.
However, it will require you to build your own hardware.
Thank you for your answer.
Can you connect a display that has SPI?
(ex.Serial SPI I2C 10.1"TFT LCD Module Dislay w/RA8876,OPTL Touch Panel)
You can write python code using the pyb SPI module for that.
