I’m making a code that makes a robot follow a red ball. I’ve got the code from the following video https://youtu.be/e14cx2qFiDk?si=h-IzkDK4yAwuUQj2
I used the codes from the video and named also named them the same. Yet it keeps on giving an error saying: ImportError: no module named ‘car’.
Here is the code that I used:
import sensor, image, time
import car
from pid import PID
sensor.skip_frames(10)
red_threshold = (55, 80, 20, 70, 0, 25)
size_threshold = 2000
x_pid = PID(p=0.5, i=1, imax=100)
h_pid = PID(p=0.05, i=0.1, imax=50)
def find_max(blobs):
max_size=0
for blob in blobs:
if blob[2]*blob[3] > max_size:
max_blob=blob
max_size = blob[2]*blob[3]
return max_blob
blobs = img.find_blobs([red_threshold])
if blobs:
max_blob = find_max(blobs)
x_error = max_blob[5]-img.width()/2
h_error = max_blob[2]*max_blob[3]-size_threshold
print("x error: ", x_error)
img.draw_rectangle(max_blob[0:4])
img.draw_cross(max_blob[5], max_blob[6])
x_output=x_pid.get_pid(x_error,1)
h_output=h_pid.get_pid(h_error,1)
print("h_output",h_output)
car.run(10,-10)
car.run(-h_output-x_output,-h_output+x_output)
car.run(10,-10)
Ayisha
