Image is not saving into internal storage of the H7
import serial
import cv2
def send_command(command):
    ser.write(command.encode('utf-8') + b'\r\n')
    time.sleep(1)  # Adjust as needed
def read_response():
    response = ser.readline().decode('utf-8')
    return response.strip()
ser = serial.Serial('COM11', baudrate=9600, timeout=1)
    send_command('import os')
    send_command('import pyb')
    send_command('import sensor')
    send_command('sensor.reset()')
    time.sleep(2)  # Allow time for the sensor to reset
    print(read_response())  # Print response after sensor reset
    send_command('sensor.set_pixformat(sensor.RGB565)')
    send_command('sensor.set_framesize(sensor.QVGA)')
    send_command('sensor.skip_frames(time=2000)')
    for i in range(6):  # Capture four images
        send_command('img = sensor.snapshot()')
        print(read_response())  # Print response after image capture
        send_command('os.sync()')
        send_command('img.save("temp/temp{}.jpg")'.format(i))  # Save with different filenames
        print(read_response())  # Print response after saving the image
        print("Image {} captured and saved to temp{}.jpg".format(i+1, i))
finally:
    send_command('pyb.soft_reset()')
    ser.close()
time.sleep(4)
Directory containing the images
image_folder = 'E:\\temp'
Output video file name
video_name = 'D:\\output_video4.avi'
Get the list of image filenames in the directory
images = [img for img in os.listdir(image_folder) if img.endswith(".jpg")]
Sort the image filenames to ensure they are in the correct order
images.sort()
Get the dimensions of the first image to use for video size
frame = cv2.imread(os.path.join(image_folder, images[0]))
height, width, layers = frame.shape
Define the codec and create VideoWriter object
fourcc = cv2.VideoWriter_fourcc(*'XVID')
video = cv2.VideoWriter(video_name, fourcc, 1, (width, height))
Iterate through the images and add them to the video
for image in images:
    video.write(cv2.imread(os.path.join(image_folder, image)))
Release the video writer object
video.release()
print(f"Video '{video_name}' created successfully.")
this is the code , i used earlier to take snap and save that to the internal storage of the openmv H7, now but now it is not saving the images to the internal storage, once i connect the camera , i just open the openmv and connect the device to the system, i do test run, after that i run this program in pycharm, First time it works well takes picture and saves it and gives responce and everything, the same if i run second time it work. after that if i run n number of times it wont save any image to defined location.
now, i am able to access the camers for each run and able to save image to temp folder, but in storage the image size showing as zero,
unable to save the image to the root
Hi, I see that you are controlling the OpenMV Cam via a program on the PC.
There are easier ways to get images off it. Please see this script: openmv/tools/pyopenmv_fb.py at master · openmv/openmv
It pulls the frame buffer using the same debug protocol as OpenMV IDE. You can just send scripts, pull text, and the frame buffer to the PC.
The method you are using trying to write files to the camera disk and then pull them is not the best to use.
