How to take apart the casing of AE3
I really like the cute blue case of AE3, but now I need to fix AE3 to a drone. I think it may be better to fix it with screws of the board than double-sided tape on the case. Is there any image or diagram about how to take apart the casing of AE3. I do not want to break the case. Thank you very much
The screws on the AE3 are M1.6. There are holes on the case. Do not take the case off. The MCU runs at 0.8V. Static shock from you touch it will cause it to reset or damage to the MCU. Additionally, the case fills a functional role of preventing light from entering the back of the PCB and washing out the sensor.
Just buy M1.6 screws, get ones 12mm or longer. Install the AE3 using these screws. Never take the case off.
Thank you so much for super helpful reply. Thank God I ask first before trying to open it.
