GENX320 in event mode
I’m using a GENX320 event camera sensor and a RT1062 board. I modified the firmware to fetch the event raw data by setting "OMV_GENX320_EHC_ENABLE " to be “0”. I want to get the (x,y,t) values for each event from the IDE, but I don’t know how to modify the code.
Many thanks,
Dec
Hi, the camera driver post-processes the event data in this case. It’s already going through x/y to create an image, but, the t is thrown away.
Given a lot of folks have been asking about this… I’ll just add a feature in the firmware so you can use this mode. It’s really not a great mode. But, folks seem to want it so I’ll see what I can do to support it.
EDIT: I’ll think about this, but, it’s probably a no. The camera can generate about 2M+ events per second. If you try to process this in python your FPS will be like sub 1 frame a second given all the mallocing and etc. you have to do to get frames.
Maybe I can return an ndarray instead of an image object of the pixels and their times. But, this is still a large number of mallocs per second for the event buffer.
Thanks for the reply. I’m wondering if it is possible to only record (x,y,t) in a txt file or a raw format without showing the image in the IDE. Then, I can do post processing on my PC after recording or real-time image reconstruction using my PC’s CPU.
I think if the threshold is setting properly, only a few pixels will generate events, so the event number may not be quite large.
Hi, I’m going to get a meeting setup with Prophesee to see how to make this feature work. I’m the meantime, please use historgram mode and just set the frame rate. The integration time per pixel is then 1/framerate.
Many thanks. Hoping to see the code update.
I would also like to know how to get the event data (x, y, t, polarity) of the GENX320 event camera on openmv, and I am very much looking forward to OpenMV supporting the output of event data
I’m focused on an IDE release right now for this weekend.
Prophesee has been alerted to the request and they are thinking of the best API. Once I get feedback I will try to work on this one upcoming weekend.
I’m wondering if there is any progress on this. Many thanks.
Hi, we’ve come to a spec agreement with Prophesee, I will start work on it later next month.
Hi @kwagyeman — appreciate the updates so far!
Just checking: are you working on the GenX320 event-mode Python API right now, and if so is there an estimated timeline? In the meantime, could you share a minimal example showing how to pull raw event data (x, y, polarity) via the current Python interface?
Thanks!
I’ll start work on it this weekend. I just have to finish another PR first before it. I expect to complete support for it in about 2 days.
Hi, kwagyeman. June is coming to an end, is there any new progress on the event camera GENX320 output event data?
Working on it right now.
Hello @kwagyeman
I just got a Genx320 and imm getting started with accessing event data using openmv/scripts/examples/01-Camera/03-Event-Cameras/02-Genx320/genx320_event_mode.py at master · openmv/openmv
however, i get hit with - AttributeError: 'module' object has no attribute 'IOCTL_GENX320_SET_MODE' line openmv/scripts/examples/01-Camera/03-Event-Cameras/02-Genx320/genx320_event_mode.py at cafcc357ef48ae7de2eab2abca6fa62a4aea2fb4 · openmv/openmv · GitHub
could you help me get the right drivers or the code? where can i find some documentation?
EDIT1
I reinstalled the cam firmware and cleared ROMFS and Fat filesystem. I get the error now as
AttributeError: 'module' object has no attribute 'CSI' from line 30
EDIT2
I see the raw sensor event is currently in development release, could you specify which is the right firmware for openmv cam h7 plus?
Hi, do:
Tools→Install latest development firmware in the IDE.
Then you can use all the scripts on github.
There’s no documentation yet for the feature yet except in the example scripts. However, pretty much everything you need to know is in the example scripts.
Once we do a firmware release we’ll have docs online and the example scripts will be in the IDE.
Hi @kwagyeman,
It has been a while. Is any progress on the event mode of GENX320?
Dec
As mentioned in the previous discussion, OpenMV has supported event mode for a while. If you’ve followed the earlier conversation, you should already know how to configure the GENX320 event camera.
Additionally, the link provided contains details on setting up the GENX320 in event mode.
We will be doing a firmware release in November and all documentation and examples in the IDE will be updated. Along with a new IDE version with lots of bug fixes. Then afterwards, we are updating the OpenMV protocol and OpenMV IDE for another release in December.
