Hello and many thanks for awesome product.
Do you have any plans to implement Gabor filter? It is very useful and we rely on it in threaded parts detection in manufacturing.
Now we use RPi but wanted to switch to OpenMV due to its better embedability and debug simplicity.
You should just hand code the kernels for use, then use the morph() method on the image.
You can create copies of the small image patch you want to look at with crop() and then morph() the different kernels there. You can then sum up each morphed image using a method like get_stats() to commute image stats.
