I have a OpenMV H7 Plus with a Lepton Module. The code has been running fine until I upgraded the FW to 4.1.0.
I am now getting the following error:
RuntimeError: The requested operation is not supported on the current pixel format
sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True)
sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_RANGE, min_temp_in_celsius, max_temp_in_celsius)
Thoughts? Thanks, Curtis
It’s bug in checking the ioctl number of args, some recent changes that improve error reporting broke it. Here’s a workaround for now just add any extra arg, and I will fix it in the next release:
sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_MODE, True, 0)
sensor.ioctl(sensor.IOCTL_LEPTON_SET_MEASUREMENT_RANGE, min_temp_in_celsius, max_temp_in_celsius, 0)
That was it. Thanks for the help and quick response! Curtis
