Errors when using sensor.IOCTL_LEPTON_xxx
Hello all,
meanwhile I received my Flir Lepton 3.5. Together with the OpenMV Pure Thermal board everything works perfectly fine when using library fir.
However, all examples using sensor.IOCTL_LEPTON_xxx cause error messages. My assumption: the documentation mentioned something that OpenMV Pure Thermal is using different I2C channels than other OpenMV boards.
Any suggestion on how to get this issue solved and to get sensor.IOCTL_LEPTON_xxx working?
Thanks and best regards,
Matthias
