I am attempting to connect a FLIR Lepton 3.1R to my OpenMV H7 Plus using the camera extension cable. I am getting mixed results - most of the time the integrated shutter will actuate 5 times and then produce this error:
RuntimeError: Frame capture has timed out.
However, on several occasions I have been able to get a consistent output from the camera while attached via the extension cable. To try to diagnose this inconsistency here is what I have tried that has worked:
- Running the same script with the FLIR Lepton without the extension cable
- Connecting the OV6540 sensor via the extension cable running an example script
Here is what I have tried that has not worked:
- Changing out the extension cable
- Changing out the FLIR Lepton sensor
- Changing out the H7 Plus board
- Running an example FLIR Lepton script
Any wisdom on solving this issue would be greatly appreciated!
