Frame capture has timed out
Hi there,
I am using the OpenMV H7 Cam for precision landing of a drone. I have four LED that the cam tracks, and performs a perspective 3 point method to determine the pose of the camera. I have got this running, however the camera frequently stops, sometimes showing an error of RuntimeError: Frame capture has timed out. This error occurs on:
img = sensor.snapshot().lens_corr(strength = 1.15, zoom = 1.0)
Sometimes there is no error, and the camera just stops and disconnects itself from the OpenMV IDE. The camera stops randomly after different lengths of running periods. It can range from around 50 seconds to 10 minutes.
Would you have any idea what is causing this?
Are you on the latest firmware?
Also, if the camera firmly mounted in it’s socket and does it have screws in it?
Firmware is v4.2.1.
Yes the camera is firmly mounted.
I have two cameras that I frequently interchange, and they both have this issue.
Could it be an issue of the code being too intensive?
What’s your code?
And no, we have a nice image buffer architecture that should not have issues. It sounds like a power issue or something like that. Not software.
I have attached my code below. Sorry unsure how to get the colours going
# LED Beacon Precison Landing
# Sends the drones position relative to a LED marker via Mavlink to the drones flight controller
# for autonomous precison landing.
import sensor, image, time, ulab, cmath, math, pyb, json
from pyb import Timer
sensor.set_pixformat(sensor.GRAYSCALE)  # Setiing the camera to grayscale
sensor.set_framesize(sensor.QVGA)       # Setting the cameras resolution (320 x 240)
sensor.set_auto_gain(False)             # Must be turned off for tracking
sensor.set_auto_whitebal(False)         # Must be turned off for tracking
sensor.set_auto_exposure(False, exposure_us=150)
sensor.skip_frames(time = 1000)
start = pyb.millis()                    # Start timer
#----------------------------------Variables---------------------------------------------------------------------------
# LED configuration
X4 = np.array([0, 13.5, 0]).reshape((3,1))      # 3D fourth point coordinate - X=[x,y,z] LED 5
pts3d = np.array([[  0, 13.5, 13.5],            #   [  LED_2_x, LED_3_x, LED_4_x],
              [  0,    0, 13.5],            #   [  LED_2_y, LED_3_y, LED_4_y],
              [  0,    0,    0]])           #   [        0,       0,       0]
Points= {}              # Saved blob information  {key : [x, y, LED number , start_time, stop_time, most_recent_time] }
                        # Confirmed LED numbers 2,3,4,5.    10 ->5, 8->4, 7->2, 6->3
                        # Left numbers are prerequisit LED name as period is checked twice
Old_Points = {}         # Prev saved blob information
tot_points = 2          # Key for potential new LED point
pixel_threeshold = 50   # Acceptable distance away from prev postion
reset_point_timer = 250 # Deletes point after timer (ms)
pts2d =np.ones((3,3))    # 2D LED Coord matrix
x4 = np.ones((1,3))      # Initialising 2d point coordinate array Forth Point
# Camera 1 Matrix
K = np.array([[777.14542236,           0, 310.20444678],
              [           0, 777.4151376, 243.61929354],
              [           0,           0,           1]])
#Camera 2 Matrix
K = np.array([[777.06768,           0,    300.0053],
              [        0,   776.83673,    216.3983],
              [        0,           0,           1]])
send = 0
send_timer = 10000
buff_size = 10
center_x = 0
center_y = 0
blob5 = 1
blob2 = 1
thresholds = (250, 256)             # Thresholds for bright white light from LED.
box_colour = (30, 150, 30)
medbuffer_x = np.zeros((1,10))
medbuffer_y = np.zeros((1,10))
medbuffer_z = np.zeros((1,10))
#--------------------------------Math Functions--------------------------------------------------------------------
# Dot product of two vector arrays
def dotProduct(vect_A, vect_B):
    product = 0
    n = 3
    for i in range(0, n):   # Loop to calculate the dot product
        product = product + vect_A[i] * vect_B[i]
    return product
# Calculates dot product of matrices
def dot_mat(mat1, mat2):
    row1_num, col1_num = mat1.shape()
    row2_num, col2_num = mat2.shape()
    dot = np.zeros((row1_num, col2_num))
    for row in range(0, row1_num):
        current_row = mat1[row,:]
        for col in range(0, col2_num):
            current_col = mat2[:,col]
            product = dotProduct(current_row, current_col)
            dot[row, col] = product
    return dot
# Calculates transpose of a matrix
def trans(Array):
    transposed_array = []
    for i in range(Array.shape()[1]):
        new_row = list()
        for sublist in Array:
            new_row.append(sublist[i])
        transposed_array.append(new_row)
    return np.array(transposed_array)
# --------------------- Fourth Degree Polynoimal Solver -------------------
# Solves a quartic equation using Ferrari's method.
def Quartic(h):
    A = h[0]
    B = h[1]
    C = h[2]
    D = h[3]
    E = h[4]
    m_min = 1e-20
    alpha = -3*B**2/(8*A**2) + C/A
    beta = + B**3/(8*A**3) - B*C/(2*A**2) + D/A
    gamma = -3*B**4/(256*A**4) + C*B**2/(16*A**3) - B*D/(4*A**2) +E/A
    if beta == 0:
        root1 = -B/(4*A) + cmath.sqrt( (-alpha + cmath.sqrt(alpha**2-4*gamma)) /2)
        root2 = -B/(4*A) + cmath.sqrt( (-alpha - cmath.sqrt(alpha**2-4*gamma)) /2)
        root3 = -B/(4*A) - cmath.sqrt( (-alpha + cmath.sqrt(alpha**2-4*gamma)) /2)
        root4 = -B/(4*A) - cmath.sqrt( (-alpha - cmath.sqrt(alpha**2-4*gamma)) /2)
        P= -alpha**2/12 - gamma
        Q= -alpha**3/108 + alpha*gamma/3 - beta**2/8
        Rp= Q/2 + (Q**2/4 + P**3/27)**0.5
        Rm= Q/2 - (Q**2/4 + P**3/27)**0.5
        U=Rm**(1/3)
        if(U==0):
            y=-5/6*alpha - U
           y=-5/6*alpha - U + P/(3*U)
        W=( alpha + 2*y )**(1/2)
        root1 = -B/(4*A) + 0.5 * ( + W + ( -(3*alpha + 2*y + 2*beta/(W +m_min)) )**0.5 )
        root2 = -B/(4*A) + 0.5 * ( - W + ( -(3*alpha + 2*y - 2*beta/(W+m_min)) )**0.5 )
        root3 = -B/(4*A) + 0.5 * ( + W - ( -(3*alpha + 2*y + 2*beta/(W+m_min)) )**0.5 )
        root4 = -B/(4*A) + 0.5 * ( - W - ( -(3*alpha + 2*y - 2*beta/(W+m_min)) )**0.5 )
    return [root1, root2, root3, root4]
#------------------------------PnP Solver-----------------------------------------------------------
def pnp(X, pts2d, K):
    m11 =(np.linalg.inv(K)).reshape((3,3))
    m22 =(pts2d).reshape((3,3))
    m = dot_mat(np.linalg.inv(K), pts2d)
    m = m / (np.array([ np.linalg.norm(m[:,0]) , np.linalg.norm(m[:,1]) , np.linalg.norm(m[:,2]) ]))
    # Permute m and X so that the longest distance is between X[:,0] and X[:,1]
    d =  ((np.array([X[:,1] - X[:,0],X[:,2] - X[:,1] ,X[:,0] - X[:,2]])).transpose()) ** 2
    d = np.sqrt(d[0] + d[1] + d[2])
    idx = np.argmax(d) # Finds index of maximum element in d array
    if idx == 1:
        X = trans(np.array([  X[:,1] , X[:,2], X[:,0]  ]))
        m = trans(np.array([  m[:,1] , m[:,2], m[:,0]  ]))
    elif idx ==2:
        X = trans(np.array([  X[:,0] , X[:,2], X[:,1]  ]))
        m = trans(np.array([  m[:,0] , m[:,2], m[:,1]  ]))
    X21 = X[:,1] - X[:,0]
    X31 = X[:,2] - X[:,0]
    nx = X21
    nx = nx / np.linalg.norm(nx)
    nz = np.cross(nx, X31)
    nz = nz / np.linalg.norm(nz)
    ny = np.cross(nz, nx)
    N  = trans(np.array([nx, ny, nz]))
    # Calculate coefficients of the polinomial for solving projective depths
    a = dot_mat( (np.array((N[:,0]))).reshape((1,3)) , X21.reshape((3,1)) )
    b = dot_mat( (np.array((N[:,0]))).reshape((1,3)) , X31.reshape((3,1)) )
    c = dot_mat( (np.array((N[:,1]))).reshape((1,3)) , X31.reshape((3,1)) )
    M12 = dot_mat( (np.array((m[:,0]))).reshape((1,3))  , (np.array((m[:,1]))).reshape((3,1)) )
    M13 = dot_mat( (np.array((m[:,0]))).reshape((1,3))  , (np.array((m[:,2]))).reshape((3,1)) )
    M23 = dot_mat( (np.array((m[:,1]))).reshape((1,3))  , (np.array((m[:,2]))).reshape((3,1)) )
    p = b/a
    q = (b**2 + c**2) / (a**2)
    f = np.array( [p[0][0], -M23[0][0],  0, -M12[0][0]*(2*p[0][0]-1),   M13[0][0],  p[0][0]-1] )
    g = np.array( [q[0][0],          0, -1,     -2*M12[0][0]*q[0][0], 2*M13[0][0],  q[0][0]-1] )
    h1 = -(f[0]**2) + g[0]*(f[1]**2)
    h2 = (f[1]**2)*g[3] - 2*f[0]*f[3] - 2*f[0]*f[1]*f[4] + 2*f[1]*f[4]*g[0]
    h3 = (f[4]**2)*g[0] - 2*f[0]*(f[4]**2) - 2*f[0]*f[5] + (f[1]**2)*g[5] - (f[3]**2) - 2*f[1]*f[3]*f[4] + 2*f[1]*f[4]*g[3]
    h4 = (f[4]**2)*g[3] -  2*f[3]*(f[4]**2) - 2*f[3]*f[5]  - 2*f[1]*f[4]*f[5] +  2*f[1]*f[4]*g[5]
    h5 = -  2*f[5]*(f[4]**2) + g[5]*(f[4]**2) - (f[5]**2)
    h = np.array([h1, h2, h3, h4, h5])
    x = Quartic(h) # Finds the roots of fourth degree polynomial
    # Discards complex results
    x_new = []
    for i in range(4):
        if isinstance(x[i], complex):
            if ((abs((x[i].imag)))<1e-1) and (x[i].real>0):
                x_new.append(x[i].real)
            if (x[i]>0):
                x_new.append(x[i])
    x =  np.array(x_new)
    x =  np.array([1.0147, 0.9929])
    y = -np.array(((f[0]*x+f[3] )*x + f[5]) / (f[4] + f[1]*x))
    # Recovers motion
    nsols = len(x)
    A = m *  np.array([-1, 1, 0])
    B = m * np.array([-1, 0, 1])
    C = B- p*A
    R = [np.zeros((3,3)), np.zeros((3,3)), np.zeros((3,3)), np.zeros((3,3))]
    t = np.zeros((3,nsols))
    for i in range(0, nsols):
        lambda1 = (np.array([1, x[i], y[i]])).reshape((3,1))
        s = np.linalg.norm(dot_mat( A, lambda1 )) / a
        d = (lambda1/s).reshape((3,1))
        r1 = dot_mat(A,d) /a
        r2 = dot_mat(C,d) /c
        r31 = r1[1][0]* r2[2][0]  - (r1[2][0]) * (r2[1][0])
        r32 = r1[2][0]* r2[0][0]  - (r1[0][0]) * (r2[2][0])
        r33 = r1[0][0]* r2[1][0]  - (r1[1][0]) * (r2[0][0])
        r3 = np.array([r31, r32, r33])
        Rc = trans(np.array([ [r1[0][0], r1[1][0], r1[2][0]] , [r2[0][0], r2[1][0], r2[2][0]] ,  [r3[0], r3[1], r3[2]] ]))
        tc = (d[0]*m[:,0])
        tc[2] = (0.496283567*tc[2]) - 6.2002684 # Scales z into centimeters
        tc[0], tc[1] = scaling(tc[2], tc[0], tc[1]) # Scales x and y into centimeters based on the z position
        R[i] = dot_mat(Rc, trans(N))  # Rotation matrix
        t[:,i] = tc                   # Adds new translation to the translation matrix
    return R, t
#--------------------------------------Selects most plausible solution ---------------------------------------------
# A fourth point is used to find the best solution by selecting the solution with the minimal error
def best_solution(R, t, X4, m4):
    min_error = float('inf')
    min_idx = []
    for ii in range(t.shape()[1]):
        m2 = dot_mat((R[ii].reshape((3,3))), (X4)) + (t[:,ii].reshape((3,1)))
        m2 = m2 / m2[2]
        error = np.linalg.norm(m4 - m2)  # Compares predicted fourth point pixel position to the actual position
        if error < min_error:
            min_error = error
            min_idx = ii
    return R[min_idx], t[:, min_idx]
# ------------------------MAVLINK-----------------------------------------------------------------------
uart_baudrate = 115200
MAV_system_id = 1
MAV_component_id = 0x54
MAX_DISTANCE_SENSOR_enable = True
lens_mm = 2.8           # Standard Lens.
lens_to_camera_mm = 22  # Standard Lens.
sensor_w_mm = 3.984     # For OV7725 sensor - see datasheet.
sensor_h_mm = 2.952     # For OV7725 sensor - see datasheet.
x_res = 320 # QVGA
y_res = 240 # QVGA
f_x = (lens_mm / sensor_w_mm) * x_res
f_y = (lens_mm / sensor_h_mm) * y_res
c_x = x_res / 2
c_y = y_res / 2
h_fov = 2 * math.atan((sensor_w_mm / 2) / lens_mm)
v_fov = 2 * math.atan((sensor_h_mm / 2) / lens_mm)
# Link Setup
uart = pyb.UART(3, uart_baudrate, timeout_char = 1000)
# Helper Stuff
packet_sequence = 0
def checksum(data, extra): # https://github.com/mavlink/c_library_v1/blob/master/checksum.h
    output = 0xFFFF
    for i in range(len(data)):
        tmp = data[i] ^ (output & 0xFF)
        tmp = (tmp ^ (tmp << 4)) & 0xFF
        output = ((output >> 8) ^ (tmp << 8) ^ (tmp << 3) ^ (tmp >> 4)) & 0xFFFF
    tmp = extra ^ (output & 0xFF)
    return output
MAV_DISTANCE_SENSOR_message_id = 132        # Mavlink message number
MAV_DISTANCE_SENSOR_min_distance = 1        # in cm
MAV_DISTANCE_SENSOR_max_distance = 10000    # in cm
MAV_DISTANCE_SENSOR_type = 0                # MAV_DISTANCE_SENSOR_LASER
MAV_DISTANCE_SENSOR_id = 0                  # unused
MAV_DISTANCE_SENSOR_orientation = 25        # MAV_SENSOR_ROTATION_PITCH_270
MAV_DISTANCE_SENSOR_covariance = 0          # unused
MAV_DISTANCE_SENSOR_extra_crc = 85
def send_distance_sensor_packet(t_best):
    global packet_sequence
    temp = struct.pack("<lhhhbbbb",
                       0,
                       MAV_DISTANCE_SENSOR_min_distance,
                       MAV_DISTANCE_SENSOR_max_distance,
                       min(max(int(t_best[2]), MAV_DISTANCE_SENSOR_min_distance), MAV_DISTANCE_SENSOR_max_distance),
                       MAV_DISTANCE_SENSOR_type,
                       MAV_DISTANCE_SENSOR_id,
                       MAV_DISTANCE_SENSOR_orientation,
                       MAV_DISTANCE_SENSOR_covariance)
    temp = struct.pack("<bbbbb14s",
                       14,
                       packet_sequence & 0xFF,
                       MAV_system_id,
                       MAV_component_id,
                       MAV_DISTANCE_SENSOR_message_id,
                       temp)
    temp = struct.pack("<b19sh",
                       0xFE,
                       temp,
                       checksum(temp, MAV_DISTANCE_SENSOR_extra_crc))
    packet_sequence += 1
    uart.write(temp)
MAV_LANDING_TARGET_message_id = 149
MAV_LANDING_TARGET_min_distance = 1/100 # in meters
MAV_LANDING_TARGET_max_distance = 10000/100 # in meters
MAV_LANDING_TARGET_frame = 8 # MAV_FRAME_BODY_NED
MAV_LANDING_TARGET_extra_crc = 200
def send_landing_target_packet(t_best, w, h, center_x, center_y):
    tot_distance =  pythagoras( ( pythagoras(t_best[0], t_best[1])) , t_best[2])
    temp = struct.pack("<qfffffbb",
                       0,
                       ((center_x / w) - 0.5) * h_fov,
                       ((center_y / h) - 0.5) * v_fov,
                       min(max(tot_distance/100 , MAV_LANDING_TARGET_min_distance), MAV_LANDING_TARGET_max_distance),
                       0.0,
                       0.0,
                       0,
                       MAV_LANDING_TARGET_frame)
   temp = struct.pack("<bbbbb30s",
                       30,
                       MAV_system_id,
                       MAV_component_id,
                       MAV_LANDING_TARGET_message_id,
                       temp)
    temp = struct.pack("<b35sh",
                       0xFE,
                       temp,
                       checksum(temp, MAV_LANDING_TARGET_extra_crc))
    uart.write(temp)
# ----------------------------------Flickering LED tracking functions----------------------------------------------
# Changes y and x scaling factor depending on z position
def scaling(z_distance, x_value, y_value):
    x_intercept = -0.41105*z_distance + 1.793
    y_intercept = 0.316428814*z_distance + 0.45969444
    x_scaled = x_intercept - x_value
    y_scaled = y_intercept + y_value
    return x_scaled, y_scaled
# Finds average of a list
def average(pixel_list):
    return sum(pixel_list) / len(pixel_list)
def pythagoras(a, b):
    return np.sqrt( (a)**2 + (b)**2 )
# Loops through previous saved points and see's if any of the new blobs meet the critera
# Updates positions of points to new blob postions if the blob coordinates are within an area threshold
def Updating_Points(Points, blob_list):
    blob_found = np.zeros((1, len(blob_list)+1)) # Zero if not found, set to one if blob within point area threshold
    for num in list(Points.keys()):
        found = 0   # flag which is set to one if a blob meets critera
        tot_error = float("inf")
        counter = 0
        for blob in blob_list:
            counter = counter + 1
            ratio = blob.w() / blob.h()
            blobx = blob.cx()
            bloby = blob.cy()
            if (ratio >= 0.6) and (ratio <= 1.4):
                img.draw_cross(blobx, bloby)
                # Checks if the blobs coordinates are within the area threehold of the previous points coordinates
                if (Points[num][0] + pixel_threeshold ) > blobx > (Points[num][0] - pixel_threeshold ) and (Points[num][1] + pixel_threeshold ) > bloby  > (Points[num][1] - pixel_threeshold ):
                    error_dist =  pythagoras(blobx - Points[num][0], bloby - Points[num][1]) # Finds pixel distance between previous point and new blob position
                    # Saves blob closet to previous saved point
                    if error_dist < tot_error:
                        tot_error = error_dist
                        best = blob
                        blob_counter = counter
                        found = 1
        # Updates point coordinates to best saved blob position
        if len(blob_list) > 0 and found == 1:
            Points[num][0] = best.cx()
            Points[num][1] = best.cy()
            # Reset start and stop times
            if Points[num][4] > Points[num][3]:
                Points[num][3] = pyb.elapsed_millis(start)
                Points[num][4] = 1
            Points[num][5] = pyb.elapsed_millis(start)
            found = 1
            blob_found[0][blob_counter-1] = 1
    return Points, blob_found
# Removes any duplicates and sets them to the value in Old_Points dictionary
def remove_duplicates(Points, Old):
    temp = []         # List of x positions
    temp2= []         # List of y positions
    keys_saved = []   # List of keys
    double_keys = []  # List of keys found to have the same x and y coordinates saved
    res = dict()      # New dictionary for LED points
    # Finds duplicate points and adds them to double_keys list
    for key, val in Points.items():
        found_flag = 0
        if len(temp2) > 0:
            for index in range(len(temp)):
                if val[0] == temp[index] and val[1] == temp2[index]:
                    found_flag = 1
        # Check if postions if not alread found
        if found_flag == 0:
            temp.append(val[0])
            temp2.append(val[1])
            keys_saved.append(key)
            res[key] = val
        # Finds duplicate points and adds them to double array.
            for i in range(len(temp)):
                if temp[i] == val[0] and temp2[i] == val[1]:
                    current = keys_saved[i]
                    if current not in double_keys:
                        double_keys.append(current)
                    if key not in double_keys:
                        double_keys.append(key)
    dist_list = []
    # Sort which position is right for each key in doubles list.
    # The keys previous position in the old dicionary will be compared to the new position
    # and the key with the smallest difference in distance will be set to this posiiton.
    # The other duplicate keys will be set to their old position.
    if len(double_keys) > 0:
        new_point = Points[double_keys[0]]
        for key_idx in range(len(double_keys)-1):
            key = double_keys[key_idx]
            current = double_keys[key_idx + 1]
            # Compare distances of points
            distance1 = pythagoras((Old[str(key)][0] - new_point[0]), (Old[str(key)][1] - new_point[1]))
            distance2 = pythagoras((Old[str(current)][0] - new_point[0]), (Old[str(current)][1] - new_point[1]) )
            if distance1 > distance2:
                res[key]        = Old[str(key)]
                dist_list.append( (distance1, key) )
                if distance2 < dist_list[0][0]:
                    res[dist_list[0][1]]   = Old[str(dist_list[0][1])]
                    dist_list[0] = (distance2,current)
                    res[current] = Old[str(current)]
                dist_list.append( (distance2, current) )
                if distance1 < dist_list[0][0]:
                    dist_list[0] = (distance1, key)
        key = dist_list[0][1]
        res[key][5] = pyb.elapsed_millis(start)
        if Old[str(key)][3] == res[key][3]:
            res[key][0]  = Points[key][0]
            res[key][1]  = Points[key][1]
        if res[key][4] > res[key][3]:
            res[key][3] = pyb.elapsed_millis(start)
            res[key][4] = 1
    return res
# Determines if point is blinking at the correct period to be an LED
def LED_Finder(res, Old, pts2d, blob5, blob2, center_x, center_y):
    flag_Detect = 4
    flag_off = 0
    Points3or4 = []
    LED_x_pixels = []
    LED_y_pixels = []
    # Finds blobs period and determines if they are LEDs
    for key_final, val_final in res.items():
        send = 0
        # Set stop time when stops detecting blob
        if val_final[5] - pyb.elapsed_millis(start) < -50 and val_final[4] == 1:
            res[key_final][4] =  pyb.elapsed_millis(start)
        # Compares blobs periods to wanted periods
        if 1000 < (val_final[4] - val_final[3]) < 1150:
            if res[key_final][2] == 1 or res[key_final][2] == 6 or res[key_final][2] == 10 or res[key_final][2] == 8:
                res[key_final][2] = 7
                res[key_final][4] = 99999999
            elif res[key_final][2] == 7 and blob2 == 1:
                res[key_final][2] = 2
                blob5 = 0
           elif res[key_final][2] == 7:
            flag_off = flag_off +1
        flag = 0
        if 850 < (val_final[4] - val_final[3]) < 1000:
            Points3or4.append(key_final)
            flag = 1
        elif 700 < (val_final[4] - val_final[3]) < 850:
            if res[key_final][2] == 1 or res[key_final][2] == 6 or res[key_final][2] == 8 or res[key_final][2] == 7: # needs to see period twice before confirmed
                res[key_final][2] = 10
            elif res[key_final][2] == 10 and blob5 ==1:
                res[key_final][2] = 5
                blob5 = 0
            elif res[key_final][2] == 10:
        # Adds LED positions to pts2d matrix for pnp
        if val_final[2] == 2:
            pts2d[0,0] = val_final[0]
            pts2d[1,0] = val_final[1]
            LED_x_pixels.append(val_final[0])
            LED_y_pixels.append(val_final[1])
            img.draw_cross(val_final[0], val_final[1], (40, 150, 40))
            img.draw_circle(val_final[0], val_final[1], 4, (40, 150, 40))
            flag_Detect = flag_Detect - 1
        elif val_final[2] == 3:
            pts2d[0,1] = val_final[0]
            pts2d[1,1] = val_final[1]
            flag_Detect = flag_Detect -1
        elif val_final[2] == 4:
            pts2d[0,2] = val_final[0]
            pts2d[1,2] = val_final[1]
        elif val_final[2] == 5:
            x4[0][0] = val_final[0]
            x4[0][1] = val_final[1]
            img.draw_circle(val_final[0], val_final[1], 3, (40, 150, 40))
        if flag_Detect == 0 and flag_off ==0:
            send = 1                            # If 1 send LED info to pnp
            center_x = average(LED_x_pixels)    # Average x pixel of beacon
            center_y = average(LED_y_pixels)    # Average y pixel of beacon
        # Removes points after it has not been detected for a certain amount of time or near edge of image
        if (val_final[5] - pyb.elapsed_millis(start) < -reset_point_timer) and val_final[2] != 1:
            res.clear()
            Points3or4.clear()
            blob5 = 1
            blob2 = 1
        elif (val_final[5] - pyb.elapsed_millis(start) < -reset_point_timer) or (2 > val_final[0] > 318) or (2 > val_final[1] > 238):
            del res[key_final]
            if flag == 1:
                del Points3or4[-1]
    # Sorts between LED 4 and 3 which flicker at the same frequency
    if len(Points3or4) == 2 and (pts2d[0,0] != 1 or pts2d[1,0] != 1) :
        pt1 = Points3or4[0]
        distance1 = pythagoras( (res[pt1][0] - pts2d[0,0]), (res[pt1][1] - pts2d[1,0]))
        distance2 = pythagoras( (res[Points3or4[1]][0] - pts2d[0,0])  , (res[Points3or4[1]][1] - pts2d[1,0])  )
            if res[Points3or4[0]][2] == 1 or res[Points3or4[0]][2] == 6 or res[Points3or4[0]][2] == 10 or res[Points3or4[0]][2] == 7:
                res[Points3or4[0]][2] = 8
                res[Points3or4[0]][4] = 99999999
            elif res[Points3or4[0]][2] == 8:
                res[Points3or4[0]][2] = 4
                pts2d[0,1] = res[Points3or4[0]][0]
                pts2d[1,1] = res[Points3or4[0]][1]
            if res[Points3or4[1]][2] == 1 or res[Points3or4[1]][2] == 8 or res[Points3or4[1]][2] == 10 or res[Points3or4[1]][2] == 7:
                res[Points3or4[1]][2] = 6
                res[Points3or4[1]][4] = 99999999
           elif res[Points3or4[1]][2] == 6:
                res[Points3or4[1]][2] = 3
                pts2d[0,1] = res[Points3or4[1]][0]
                pts2d[1,1] = res[Points3or4[1]][1]
            if res[Points3or4[0]][2] == 1 or res[Points3or4[0]][2] == 8 or res[Points3or4[0]][2] == 10 or res[Points3or4[0]][2] == 7:
                res[Points3or4[0]][2] = 6
            elif res[Points3or4[0]][2] == 6:
                res[Points3or4[0]][2] = 3
            if res[Points3or4[1]][2] == 1 or res[Points3or4[1]][2] == 6 or res[Points3or4[1]][2] == 10 or res[Points3or4[1]][2] == 7:
                res[Points3or4[1]][2] = 8
            elif res[Points3or4[1]][2] == 8:
                res[Points3or4[1]][2] = 4
    return res, send, pts2d, blob5, blob2,  center_x, center_y
# Adds new points if not already in point dictionary
def new_point(blob_found, blob_list, Points, tot_points):
    if len(blob_list) > 0:
        for i in range(len(blob_found[0])-1):
            blob = blob_list[i]
            # Checks if the blob has been added already and if it fits the critera
            if blob_found[0][i] == 0 and (ratio >= 0.6) and (ratio <= 1.4):
                if len(Points) > 0:
                    found1 = 0
                    for ii in Points.keys():
                        if blob.cx() == Points[ii][0] and  blob.cy() == Points[ii][1]:
                            found1 = 1
                            Points[ii][3] = pyb.elapsed_millis(start)
                            Points[ii][4] = 1
                            Points[ii][5] = pyb.elapsed_millis(start)
                if len(Points) == 0 or found1 == 0:
                    Points[tot_points] = [ blob.cx(), blob.cy(), 1, pyb.elapsed_millis(start), 1, pyb.elapsed_millis(start)] # Adding new point
                    # Increase total key count
                    if tot_points < 30:
                        tot_points = tot_points +1
                        tot_points = 1
    return Points, tot_points
#-----------------------------------------Main Loop----------------------------------------------------------------------------
    img = sensor.snapshot().lens_corr(strength = 1.15, zoom = 1.0)                               # Lens correction to fix lens distortion in an image
    blob_list = img.find_blobs([thresholds], pixels_threshold=10, area_threshold=10, merge=True) # List of all blobs of white pixels larger than the set thresholds
   # print("Compactness:", blob.compactness())
   # print("Roundness:", blob.roundness())
   # print("Area Threshold:", blob.area())
   # print("Pixel Threshold:", blob.pixels())
    Points, blob_found = Updating_Points(Points, blob_list)
    if len(Points) > 0:
        Points = remove_duplicates(Points, Old_Points) # Removes any duplicates and sets them to the value in Old_Points dictionary
        Points, send, pts2d, blob5, blob2, center_x, center_y = LED_Finder(Points, Old_Points, pts2d, blob5, blob2, center_x, center_y)
    Points, tot_points = new_point(blob_found, blob_list, Points, tot_points) # Adds new points if not already in point dictionary
    if send == 1:
        R, t = pnp(pts3d, pts2d, K)                  # Finds rotation and transtion of camera relative to marker
        R_best, t_best = best_solution(R, t, X4, x4) # A foruth point is used to find the best solution by selecting the solution with the minimal error
       # send_distance_sensor_packet(t_best) # Mavlink Message
       # send_landing_target_packet(t_best, img.width(), img.height(),center_x ,center_y) # Mavlink Message
        print(t)
        print(t_best)
        print(' ')
        print('--------------')
    Old_Points = json.loads(json.dumps(Points)) # Saves current points into an old points dictionary
The openMV is connected to the computer via usb.
We can’t debug this, we need a minimal, self-contained example that reproduces the issue to debug, otherwise our guess is as good as yours.
I have just tested this with example codes such as ir_beacon_grayscale_tracking.py and the same thing occurs. The camera stops capturing images, Serial terminal stops printing, all without an error. The camera only ran for 20 seconds before it stopped.
After waiting a couple minutes after stopping, an error came up saying: Timeout error while getting firmware version!
Are you saying that ir_beacon_grayscale_tracking.py has the same issue ? If not, please provide a minimal example that reproduces this issue.
Yes ir_beacon_grayscale_tracking.py had the same issue
Is this an OpenMV4 or OpenMV4+ (with SDRAM) ?
I’ve been running ir_beacon_grayscale_tracking.py on OpenMV4 with 4.2.1 firmware, for about 10-15 minutes straight with No issues at all, it’s running stable at ~60FPS. I’d check the USB cables, USB connector or try a different port. There’s not much else that I can do without seeing the issue.
I encountered the same error as you and published it, but I ran ir_beacon_grayscale_tracking.py without error
