Due to limited space inside my robot I decided to mount the OpenMV board inside it up-side-down. I figured it will not matter much, as I can simply just flip the y coordinate of whatever results of image processing I get, and it will amount to the same thing. However, I didn’t think about things like face detection, which will not work with up-side-down faces.
I’m now thinking about what I could do. I could flip the image after taking the snapshot and before processing it – it would take some more time, but could work. I looked at the Image class, but didn’t find a way to flip or rotate the image, though.
Next thought, I could probably configure the camera sensor to flip the image – some cameras do have such a function. But again, nothing like that in the Sensor class, except maybe for the raw access to the registers. So I started to look for the datasheet for the camera sensor, thinking that if such an option exists there, it would be explained. But the datasheet is not linked from https://openmv.io/docs/openmv/hardware/index.html and a quick Google search doesn’t seem to yield anything more than a few promotional pamphlets.
FInally, I could probably use a flipped cascade for the face detection, instead of the default one. However, looking at the XML files of the OpenCV examples, it doesn’t seem like it’s a trivial operation to do.
I guess I will simply figure out how to mount the camera right side up, unless someone has any more ideas or hints?
