Just purchased an H7 which is perfect for my project. The find rects demo program works well but I would like to use x y etc to trigger on output pin. I am very much a beginner, just starting a python course but it may be a while before I can figure out how to get at these variables. I note that the documentation lists rect.x rect.y . If anyone has the time to just add one of these parameter to the find rects code it would make my life easier and allow me to to move on with the project while still learning. Many thanks.
# Find Rects Example
# This example shows off how to find rectangles in the image using the quad threshold
# detection code from our April Tags code. The quad threshold detection algorithm
# detects rectangles in an extremely robust way and is much better than Hough
# Transform based methods. For example, it can still detect rectangles even when lens
# distortion causes those rectangles to look bent. Rounded rectangles are no problem!
# (But, given this the code will also detect small radius circles too)...
import sensor, image, time
sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
# `threshold` below should be set to a high enough value to filter out noise
# rectangles detected in the image which have low edge magnitudes. Rectangles
# have larger edge magnitudes the larger and more contrasty they are...
for r in img.find_rects(threshold = 10000):
img.draw_rectangle(r.rect(), color = (255, 0, 0))
for p in r.corners(): img.draw_circle(p[0], p[1], 5, color = (0, 255, 0))
print(r)
print("FPS %f" % clock.fps())
