I have been looking around to see if anyone else has asked this, but I haven’t found anything that directly answers my question yet.
I am attempting to take pictures (.bmp) saved on the SD card and transfer them to a computer at a long distance away. Where I am attaching the camera has an available fiber optic cable with a converter to go from an ethernet cable to fiber optic and then back on the computer end.
My current thought is to use the the UART Tx/Rx on the H7R2 (pins P0/P1 or P4/P5) connected to the appropriate wires on an ethernet cable to be converted to the fiber in a meter (probably shorter but still an unknown at the moment). Ethernet cables have a Tx+/Tx- and Rx+/Rx- as a twisted pair, but I think for the short distance I should be able to just use one of each. The receiving end of the fiber will also be a short run to the computer.
So my questions are:
- Am I able to use UART to send the file over an ethernet/fiber cable system with that connection to the camera?
- If I do need to use the Tx+/Tx- and Rx+/Rx- can I use both P0/P1 and P4/P5 to give the differential signal?
- Is the RPC library the proper thing to use to make the file transfer in this case or is there something else I should be using?
Thanks you for any any help you can give.
