face tracking with servos
I have ladyada’s mini pan tilt kit
I have ide version 1,5
also updated the firmware
I have tested servos with arduino, no problem there, they work.
also tested servos with arduino they work,
finally tested servos with servo_control.py from examples it also works (with some vibration)
but when i load face_tracking.py from examples, it finds my face but servos doesn’t move
I feed servos with external 5v, connecting servo data line to P7 and P8, also common ground with external supply and openmv cam.
I noticed face tracking doesnt have import Servo, i have added it, still no juice.
In the youtube videos of Ibrahim Abdelkader have seen he is controling servos with arduino,
is it necessery ? or just openmv connection is enough ?
or may be with arduino are you getting more precise control of servos
Could you please help me to solve how to facetrack
Thanks in advance
Hi, we didn’t write a script to control the servos while tracking a face. You’ll have to write the code for that for now.
Please see the Board-Control → servo_control.py script for how to drive the servos. Then, take that code and bring it into the facetracking script. You’ll have to write the proportional control loop yourself.
Do you need help writing the proportional control loop for the servos?
I would really appreciate help
My final project will be something like this :
After solving pan/tilt I am thinking of forward and backward with wheels, with somehow checking object size (like if it’s smaller go forward)
Thanks in advance
Alright, the first step is to setup the hardware platform. Please build up everything and connect all the wires and so forth. Once you have everything setup please run the servo example script to have the servos pan around in a circle. Please tweak the servo test script until you’re able to get at least 90 degrees of motion from both the pan and tilt axes. Once you know what the ranges are, please let me know what the min and max pulse width for both the pan and tilt servos are and which direction the system moves to for the min and max pulse widths. Once I know this information I can give you the rough starter code for proportional control.
(I’m assuming you understand how servos work and such here. If not please read up about them: Whats a servo: A quick tutorial).
For tilt (horizontal)
Full Range is between 0 and 2400
When you raise (up) the value it moves counter-clockwise
mid point for 1800 (looks direct ahead)
useable range is 1400 (45 degrees to the left) to 2200 (45 degrees to the right)
For pan (vertical)
Full Range is between 800 (looks directly to the ceiling) and 2400 (looks down)
when u raise (up) the value it moves down
mid point for 1500 (looks direct ahead)
usable range is 1100 to 1900 (90-100 difference in degree i think)
    for i in range(800):
        s1.pulse_width(1400 + i)
        time.sleep(5)
        s2.pulse_width(1100 + i)
        time.sleep(5)
        s1.pulse_width(2200 - i)
        time.sleep(5)
        s2.pulse_width(1900 - i)
        time.sleep(5)
also lower time.sleep() works better for my servos
Okay, open up the face_tracking.py script and replace this part:
while (True):
    # Extract keypoints using the detect face size as the ROI
    kpts2 = img.find_keypoints(threshold=KEYPOINTS_THRESH, normalized=NORMALIZED)
    if (kpts2):
        # Match the first set of keypoints with the second one
        c=image.match_descriptor(image.FREAK, kpts1, kpts2, threshold=MATCHING_THRESH)
        # If more than 10% of the keypoints match draw the matching set
        if (c[2]>25):
            img.draw_cross(c[0], c[1], size=5)
            img.draw_string(0, 10, "Match %d%%"%(c[2]))
    # Draw FPS
    img.draw_string(0, 0, "FPS:%.2f"%(clock.fps()))
With this:
from pyb import Servo
x_pos = 1800 # default
y_pos = 1500 # default
x_min = 1400
x_max = 2200
y_max = 1900
y_min = 1100
x_gain = +1.00 # You have to tweak this value to stablize the control loop.
               # You also may need to invert the value if the system goes
               # in the wrong direction.
y_gain = +1.00 # You have to tweak this value to stablize the control loop.
xServo = Servo(0)
yServo = Servo(1)
xServo.pulse_width(x_pos)
yServo.pulse_width(y_pos)
while (True):
    if (kpts2):
        if (c[2]>25):
            x = c[0]
            y = c[1]
            x_error = x - (img.width()/2)
            y_error = y - (img.height()/2)
            x_pos += x_error * x_gain
            y_pos += y_error * y_gain
            # Clamp output between min and max
            if (x_pos > x_max):
                x_pos = x_max
            if (x_pos < x_min):
                x_pos = x_min
            if (y_pos > y_max):
                y_pos = y_max
            if (y_pos < y_min):
                y_pos = y_min
    # Draw FPS
I haven’t actually checked if the code compiles. However, you should be able to see what I am trying to do. Basically, the control loop will increment/decrement the xPosition/yPosition of each servo. The incrementing/decrementing is clamped between a min and max. The increment/decrement is based on the face position difference from the middle of the image. So, the more the face is away from the middle of the image the stronger the response.
Your job to to make sure that you have the x output assigned to the servo that pans horizontally and the y output connected to the servo than tilts vertically. Then you need to tweak the gain value until you find something that works really well. The gain value can either be negative or positive. If its wrong you’ll notice the control loop breaking more or less right away. So, just flip the sign if that happens. If the gain value is too small the system will barely respond. If its too large the system will go crazy.
Anyway, that’s about it. Let me know if you have problems. Also, note that I’m only updating the proportional control code when a face is tracked with enough confidence.
hi again,
after finding my face; it gives error;
File “”, line 125, in
TypeError: can’t convert float to int
the line 125 is:
Do this:
xServo.pulse_width(int(x_pos))
yServo.pulse_width(int(y_pos))
Python does not convert floats to ints for you.
after your change, now it gives no error,
but the servos doesn’t come to the starting position.
i have tried this code if something were wrong with the servos, but they were working.
s1 = Servo(1) # P7
s2 = Servo(2) # P8
        s1.pulse_width(1800)
        s2.pulse_width(1500)
i also tried changing main.py with my new facetrack code and powering up with external power for more memory
still no juice
Can you try initializing the servos at the start of the script?
Also, are there any errors being printed?
oh thank you
no errors but
initialising servos first works well
finally i can play with values :slight_smile:)
hi,
it works good but sometimes it restarts or locks,
no idea why.
I also tried color tracking with servos it is way more smooother
finally,
how can i get , if the object were smaller or bigger a moment ago ?
thanks
The face tracking script uses key points which can be unwieldy right now. Use the other face tracking script which just uses the HaarCascade. The face detection script. This one should be more robust.
As for smoother tracking, the resolution determines the refresh rate which determines the the control loop speed, i.e. the smoothness.
As for determining if the object got bigger or smaller. In the face detection script you’ll get a bounding box instead of a point. SO, for that you just can look at the box area and if it was larger than previously then the object got closer. If the box area got smaller the object moved away.
Hi everybody
I received my OpenMV Cam last week and I am really thrilled about it. I have a similar Project like sertunc. I’d like to build a heliostat. (a sun tracker, that moves a mirror in a way that it always reflects the sun to the same spot) Although not entirely new to coding and stuff like that I am having my troubles finding out how I get the ranges of my servos. I ran the servo script from examples, both servos move but in a sometimes very abrupt manner. I let the script run for like 5 minutes, it did not stop, i didn’t get an output or something. Also in order to stop the script, I had to disconnect the cam, it just wouldnt stop :smiley:
It would be great if you guys could give me a hint what to do with my servos in order to be (someday) maybe able to use my servo mount for my heliostat project :slight_smile:
Hi, can you post the script you’re using? The documentation about servos is here:
http://docs.micropython.org/en/latest/pyboard/library/pyb.Servo.html
You may wish to set the servo pulse width instead of angle. As for getting the exact value of the min and max pulse width. You have to try mins and maxes out and see what works.
Hey, thanks for the quick answer!
I’ve used this:
# Servo Control Example
# This example shows how to use your OpenMV Cam to control servos.
s1 = Servo(1) # P7
s2 = Servo(2) # P8
    for i in range(1000):
        s1.pulse_width(1000 + i)
        s2.pulse_width(1999 - i)
        time.sleep(10)
        s1.pulse_width(1999 - i)
        s2.pulse_width(1000 + i)
        time.sleep(10)
here is a short video that shows my servos in action…
Okay, so you need to tune the pulse widths in that code. So, remove all the while loop stuff and just set the pulse widths manually.
s1.pulse_width(1000)
s2.pulse_width(1000)
Then check if the servo output is okay and keep changing the pulse widths until you determine the min and max range of the servos.
super, now I finally got it.
my min for both seems to be at 900 and max is at 2300
I will try out the face tracking code, maybe I can use some of it for my sun tracking heliostat project :slight_smile:
thank you very much!
Hi everybody!
I want to do project like color tracking with OpenMV and 2 axis servo
Now i cant understand how to conrol by servos
Please, help to me to writing the code
I will be very gratefull for your helpiing:)
For that moment i need help in coding.
I know how to connect the all wires but i can’t understand how to add an example code “Color tracking → single_color_rgb565_blob_tracking” so that the servos work in tandem with the camera OpenMV
Need any help! Thaks)
