Executable to convert .bin files to .bmp files on PC
Does anyone know of an executable that can be used to convert a .bin file recorded with an Openmv directly to a sequence if .bmp without having to use the IDE?
I am searching for such a tool to be able to quickly post process data fon my PC.
The bin file is our own internal format so no…
Um, so, if you specify the output file at %d.bmp ffmpeg which is used as the output processor will spot out a bmp file per frame in the bin file.
