Effective Face Detection Distance in an indoor setting with an H7 Plus with a wide-angle lens
After some initial tests and looking around this forum, I just had a quick question on the effective range of an H7 Plus using a wide-angle lens to detect faces. After some digging around here it appears that it’s just a couple of feet in some first tests that appear to be validated.
I’m just wondering if using a wide-angle lens affects it in any way and also if you have found any effective ways of extending that effective distance apart from using a zoom lens?
Thank you!
Daniel
If you increase the resolution then you should have no problem.
