I am trying to make an automatic lawn mover
when I see objects that are not green I want to back away, when I see green grass I want to cut
The blob handling is very shaky, the frame size and position vary even when the mower is stationary.
Grass is not completely green but can contain other colors such as brown.
How can I recognize objects that are mainly green and where the light from the sun also varies.
I also want to find non green objects.
In thresholds 30, 100, -64, -8, -32, 32 is set but I don’t understand what it setting?
can you give me some tip
Regards Ulf Andersson
from pyb import UART
UART 3, and baudrate.
uart = UART(3, 19200)
import sensor, image, time
threshold_index = 1 # green
Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max)
The below thresholds track in general red/green/blue things. You may wish to tune them…
thresholds = [ (30, 100, 15, 127, 15, 127),
(30, 100, -64, -8, -32, 32),
(0, 15, 0, 40, -80, -20)]# generisk röd grön blå
MesurementNo = 0
MesurementX = 320
MesurementW = 0
sensor.set_windowing((0, 40, 320, 30))
sensor.skip_frames(20)
sensor.set_auto_gain(False) #of for tracing
sensor.set_auto_whitebal(False) # of for tracing
#clock.tick()
for blob in img.find_blobs(thresholds, pixels_threshold=20, area_threshold=20, merge=True):
if blob.code() == 2: #green
Get largest rectangle and the left most
MesurementNo = MesurementNo + 1
if blob.x() < MesurementX:
MesurementX = blob.x()
if blob.w() > MesurementW:
MesurementW = blob.w()
if MesurementNo == 10:
#print(MesurementX, MesurementW , sep=', ')
xx = “%d”%MesurementX + ", " + “%d”%MesurementW + “R”
uart.write(xx)
MesurementNo = 0
MesurementX = 320
MesurementW = 0
