Can i load micropython code just on the M7 Core of the Portenta H7?
Hello everyone,
I’m trying to run some code in C++ on the M4 Core and some micropython code on the M7 Core. Is there the option to use micropython code just on the M7 Core via Open MV while M4 is running something else?
I saw that a while ago this was not possible (Portenta RPC OpenMV), is there a way to do it now? Thanks!
MicroPython already runs on the M7 and the M4 is Not used. There’s limited support for the M4, you have to build the firmware to enable it and add your code, see Portenta Micropython on M7 core, C on M4 core? - #2 by iabdalkader
