may i ask what is the effective FOV of the camera?
Thanks ![]()
Thanks ![]()
This depends on the lens you have. For example the wide angle lens has a 185 degree FOV. The standard lens that ships with your OpenMV Cam has a 115° FOV.
for the standard lens, while it is 115 deg, when i try to measure actual fov of what can be captured in the image from the left edge to the right edge of the image it seems to be about 75 degs or so. Is there anything i can do to utilize the full fov of the lens?
Hi, we sell a wider angle lens for this reason. The 2.8mm lens is just the widest angle and least expensive wide angle lens we could find to include with the camera.
