Hello!
I want to send a signal to my Arduino Mega as soon as I detect something. It worked fine with 5v, but for some reason, my camera doesn’t work with 5v anymore. So, I switched to 3.3v. The camera worked and it even sent the signal to the board. The arduino board did what it was supposed to do and sent back a signal, when it was done, but the camera didn’t receive anything…
Is that, because the communication only works with 5v? Or is it a problem with my code?
Here my OpenMV code:
w = min(max(int(blob.w() * 1.2), 10), 160) # Not too small, not too big.
h = min(max(int(blob.h() * 1.2), 10), 160) # Not too small, not too big.
x = min(max(int(blob.x() + (blob.w()/4) - (w * 0.1)), 0), img.width()-1)
y = min(max(int(blob.y() + (blob.h()/4) - (h * 0.1)), 0), img.height()-1)
out = net.forward(img.binary([(100, 255)]), softmax=True, roi=(x,y,w,h))
max_idx = out.index(max(out))
score = int(out[max_idx]*100)
if (score < 50):
score_str = "??:??%"
score_str = "%s:%d%% "%(labels[max_idx], score)
img.draw_string(0, 0, score_str, color=(0, 255, 0))
print(labels[max_idx])
if (score > 70):
if (labels[max_idx] == "H"):
print("HHHHH")
uart.write("h\r")
answerH = False
while (answerH == False):
if uart.any():
nachrichtVonArduino = uart.readchar()
nachrichtenKontrolle = 209 #ID for letter h
if (id(nachrichtVonArduino) == nachrichtenKontrolle):
print("H ist korrekt!")
answerH = True;
elif (labels[max_idx] == "S") or (labels[max_idx] == "s"): # or (labels[max_idx] == "5"):
print("SSSSS")
uart.write("s\r")
answerS = False
while (answerS == False):
if uart.any():
nachrichtenKontrolle = 231 #ID for letter S
print("S ist korrekt!")
answerS = True;
elif (labels[max_idx] == "U") or (labels[max_idx] == "u"): # or (labels[max_idx] == "v"):
print("UUUUUU")
uart.write("u\r")
answerU = False
while (answerU == False):
if uart.any():
nachrichtenKontrolle = 235 #ID for letter U
print("U ist korrekt!")
answerU = True;
Here my arduino code:
// 104: ID for h
// 115: ID for s
// 117: ID for u
// white: TX1
// black: RX1
// yellow: GND
// red: 5v/3.3v
#include <Wire.h>
void setup() {
// initialize both serial ports:
Serial.begin(9600);
Serial1.begin(9600);
Serial.println("Auf gehts!");
pinMode(9, OUTPUT); //LED
void loop() {
// read from port 1, send to port 0:
// from Camera to Arduino
if (Serial1.available()) {
int inByte = Serial1.read();
Serial.write(inByte);
if (inByte == 104)
for(int i = 0; i < 5; i++)
digitalWrite(9, HIGH);
Serial.println("ON");
delay(500);
digitalWrite(9, LOW);
Serial.println("OFF");
delay(500);
// h detected, deploying 2 rescue kits
Serial.println("");
Serial.println("H detected! Rescue procedure started...");
Serial1.write("h");
else if (inByte == 115)
delay(500);
delay(500);
// s detected, deploying 1 rescue kits
Serial.println("");
Serial.println("S detected! Rescue procedure started...");
Serial1.write("s");
else if (inByte == 117)
delay(500);
delay(500);
// u detected, deploying 0 rescue kits
Serial.println("");
Serial.println("U detected! Rescue procedure started...");
Serial1.write("u");
The camera I use is OpenMV H7, the Arduino board I use is Mega 2560. If you know it is my code, or if you know it is the camera (because it only works with 5v?), then please tell me and help me.
Thank you very much,
Finn
