Barcode detection with pin output singnal
hi guys,
i detect code 128 type barcode with i need pin output singnal
plz help
See the examples menu and bars code detection example. Then see the gpio pin control examples.
Sir
I see the examples but I don’t understand. how to get output from Pin1.
plz modified below example
https://pyimagesearch.com/2018/03/19/reading-barcodes-with-python-and-openmv/
plz help
Hi, I don’t know what you want. You seem to want us to writ ethe code for you. I will not do that.
blow code modified to barcode detection
import sensor, image, time
thresholds = [(30, 100, 15, 127, 15, 127)]
pin1 = Pin('P1', Pin.OUT_PP, Pin.PULL_NONE)
    blobs = img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200, merge=True)
    for b in blobs:
        img.draw_rectangle(b.rect())
        img.draw_cross(b.cx(), b.cy())
    pin1.value(len(blobs) == 6)
