Hello there Openmv ,
I’m having problems trying to read color blob data coming into my Arduino board,
I’m trying to read and serial print same blob data from openmv
I don’t know whats wrong, I’m new to openmv cam and I hope
bellow is the picture.I see 49,57 instead of 16 …please I appreciate your help, as I have spent days trying to solve the problem …thanks
Hi, can you test with a serial terminal and see if you’re getting the expected data ?
Please post your OpenMV Cam code and Arduino code.
OK ,Here’s the openmv code
import sensor, image, time
from pyb import UART
uart = UART(3,9600, timeout_char = 1000)
uart.write("%d"%blob.cx())
print(blob.cx())
and here’s the arduino code
int indata;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
void setup() {
Serial.begin(9600);
mySerial.begin(9600);
void loop() {
indata = mySerial.read();
Serial.print(indata);
Serial.print("\n");
Try this code:
uart.write("%d\n"%blob.cx())
print("%d\n"%blob.cx(), end='')
You had the wrong indentation in python. Also, you can’t use “blob” outside of the loop. Whatever value you were using was a stale value.
On the Arduino side:
You need a method to read a line of text. I.e. keep reading text until you see ‘/n’.
Thanks so much for your reply Sir,
now I’m 80% done, I have used the openmv code u sent and I have adjusted the Arduino code, the results are like this
I can receive the data from openmv but I need to reset before I can get a new data , that means I have to reset every time to get real-time data from openmv
here is the result …Any help to resolve this i will really appreciate .thanks in advance
the arduino code
String str;
int ds = 4;
void setup() {
Serial.begin(9600);
void loop(){
if (mySerial.available()){
delay(100); // Wait for all data.
while (mySerial.available()) {
char d = mySerial.read();
str.concat(d);
char t[str.length()+1];
str.toCharArray(t, (sizeof(t)));
int intdata = atoi(t);
Serial.print(intdata);
Serial.print("\n");
delay(100);
Try the attached. You might see some compile errors.
sketch_feb17a.zip (449 Bytes)
Thanks Sir , Everything worked well finally made a simple robot here Arduino + Openmv Cam7 ,Object Tracking Robot - YouTube
Good job! Yo may wish to turn your PID gains down a bit.
