I ran the following code on OpenMV Cam H7, FW Ver 4.3.3 and got an AttributeError: ‘tuple’ object has no attribute ‘_mpy’
import sys
sys_mpy = sys.implementation._mpy
arch = [None, 'x86', 'x64',
'armv6', 'armv6m', 'armv7m', 'armv7em', 'armv7emsp', 'armv7emdp',
'xtensa', 'xtensawin'][sys_mpy >> 10]
print('mpy version:', sys_mpy & 0xff)
print('mpy sub-version:', sys_mpy >> 8 & 3)
print('mpy flags:', end='')
if arch:
print(' -march=' + arch, end='')
print()
I am trying to cross compile .py to .mpy. I performed the following steps but am hungup at the ./mpy-cross step, getting error “./mpy-cross: No such file or directory”
- Installed Ubuntu on Windows 11
- Clone Micropython Git Repository: $ git clone GitHub - micropython/micropython: MicroPython - a lean and efficient Python implementation for microcontrollers and constrained systems
- Installed Make: $ sudo apt install make
- Installed Bash: $ sudo apt install bash
- Updated the Ubuntu package: $ sudo apt update
- Installed the build-essential package: $ sudo apt install build-essential
- Checked the GCC version: $ gcc –version
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
- Checked Bash Version: $ bash --version
GNU bash, version 5.1.16(1)-release (x86_64-pc-linux-gnu)
- Checked Python 3 installed: $ python3
Python 3.10.12 (main, Jun 11 2023, 05:26:28) [GCC 11.4.0] on linux
- Make mpy-cross: ~/micropython/mpy-cross $ make
- Run mpy-cross: ~/micropython/mpy-cross$ ./mpy-cross -h
ERROR -bash: ./mpy-cross: No such file or directory
What am I missing?
This should have run and generated a binary like this:
CC ../shared/runtime/gchelper_generic.c
LINK build/mpy-cross
text data bss dec hex filename
326528 13784 872 341184 534c0 build/mpy-cross
Is this the case?
Yes
325862 13784 872 340518 53226 build/mpy-cross
:~/micropython/mpy-cross $ ls
Makefile build main.c mphalport.h mpy_cross
README.md gccollect.c mpconfigport.h mpy-cross.vcxproj qstrdefsport.h
Can you follow this guide here first: openmv/src at master · openmv/openmv (github.com)
Typically means the file was not executable.
I found mpy-cross in the build subfolder
~/micropython/mpy-cross/build$ ls
gccollect.P gccollect.o genhdr main.P main.o mpy-cross mpy-cross.map py shared
It works from there.
~/micropython/mpy-cross/build$ ./mpy-cross -h
~/micropython/mpy-cross/build$ ./mpy-cross ~/micropython/examples/accel_i2c.py
cross compiled .mpy is not compatable. ValueError: incompatible .mpy file
From the openmv docs “Check the validity of the .mpy file by inspecting the first two bytes of the file. The first byte should be an uppercase ‘M’ and the second byte will be the version number, which should match the system version from above.”
First byte of file is ‘M’, second byte is 0x06, which matches the mpy-cross version.
:~/micropython/mpy-cross/build$ ./mpy-cross --version
MicroPython v1.23.0-preview.174.gbc424ddc4 on 2024-03-01; mpy-cross emitting mpy v6.2
Now back to my original question in this thread … How do I determine the .mpy version and flags supported by the MicroPython my system by executing?
Is this the micropython version? v1.18?
MicroPython: v1.18-omv-r13 OpenMV: v4.3.3 HAL: v1.9.0 BOARD: OPENMV4-STM32H743
From the table in the openmv docs, mycropython v1.18 is .mpy version 5.
How do I change the .mpy version to match? Where do I find the Git commit for .mpy version 5?
Uh… we’re at 4.5.2 so… you’re quite far behind the tip of the repo. The current release is at 1.20.
