Hi there,
I’m working in a project on which I need to detect people, and know where they are (in the image frame). I was using the on-board person detection model with many different ROIs (to determine where in the image the person is located). I tried using the Haar-Cascade face detector, but this performed worst than the multiple ROI approach.
Although the multiple-ROI algorithm works, this approach has some drawbacks, for example, if a person is between 2 adjacent ROIs, both of the ROIs appear to have a person inside. There is probably some workaround this, but I think a detector model like YOLO would best.
Is YOLO support comming anytime soon? Is ther a way I can load a YOLO model into a H7 plus cam?
I was previously using a K210 board which does support YOLO (Object Detection with Sipeed MaiX Boards (Kendryte K210) - Hackster.io), but I changed to the OpenMV cam since is so much better documented, and easy to use for prototypes.
Thanks a lot!
