I created a little program, that detects the color of tokens running past the camera on a conveyor-belt. Depending on the color of the detected chip, I’m then setting the percentage of the pulse of a PWM output. This is then converted into a real analog 0-24V signal.
Everything is working fine when running the program in the OpenMV IDE, but as soon as I save the program to the device and want to run it without, it only seems to be detecting red tokens for everything.
Is there anything that I need to be aware of, when running it without the IDE?
Here’s the code of the program:
import sensor, image, time
from pyb import Pin, Timer
thresholds = [
# Red
(70, 80, 10, 30, 50, 60),
# Blue
(55, 70, -20, 10, -65, -40),
# Green
(25, 100, -69, -25, -42, 26),
global_pixels_threshold = 300
global_area_threshold = 300
NO_TOKEN=0
RED_TOKEN=25
BLUE_TOKEN=50
GREEN_TOKEN=75
DAMAGED_TOKEN=100
# Initialize the output pin
p = Pin('P4') # P4 has TIM2, CH3
tim = Timer(2, freq=1000)
ch = tim.channel(3, Timer.PWM, pin=p)
ch.pulse_width_percent(NO_TOKEN)
# Initialize the image sensor
sensor.set_auto_exposure(False) # must be turned off for color tracking
color = NO_TOKEN
# Take a picture and return the image and de-fisheye the image and zoom to the completely black part of the image
img = sensor.snapshot().lens_corr(strength=1.5, zoom=1.1, x_corr=-0.03, y_corr=0.0)
# Cut out the part we're interested in (Reduces the false-positives on the sides)
img = img.crop(roi=[87,0,166,400])
# Detect Red Tokens
for blob in img.find_blobs([thresholds[0]], pixels_threshold=global_pixels_threshold, area_threshold=global_area_threshold, merge=True):
color = RED_TOKEN
img.draw_rectangle(blob.rect(), color=(255,0,0))
# Detect Blue Tokens
if color == NO_TOKEN:
for blob in img.find_blobs([thresholds[1]], pixels_threshold=global_pixels_threshold, area_threshold=global_area_threshold, merge=True):
color = BLUE_TOKEN
img.draw_rectangle(blob.rect(), color=(0,0,255))
# Detect Green Tokens
for blob in img.find_blobs([thresholds[2]], pixels_threshold=global_pixels_threshold, area_threshold=global_area_threshold, merge=True):
color = GREEN_TOKEN
img.draw_rectangle(blob.rect(), color=(0,255,0))
ch.pulse_width_percent(color)
Would be happy if I could finally finish this little project (Initially I had RED, BLUE and WHITE tokens, but detecting white reliably seems to have been sort of impossilbe, so I painted the white tokens green and now all is good … at least theoretically)
Your help is greatly appreciated.
Chris
