For OpenMV, is it possible to wake up the system from the deepsleep or standby mode, using the external trigger.
extint = pyb.ExtInt(“P0”, pyb.ExtInt.IRQ_RISING, pyb.Pin.PULL_NONE, whatever)
machine.deepsleep()
I tried a few times, it seems that the external trigger does not wake the system up.
While etc could wake it up, as stated in the library.
Hi Kwabena,
Is still wake up from deepsleep() using EXT interrupt not supported ? It would be of great help to use the very-lowpower deepsleep mode and wake up for an event using an Arduino EXT Trigger.
On the AE3, I’m only currently only able to wake up from deepsleep using the hard reset button.. I don’t see any example to wakeup using the RTC or the IMU… is this supported yet?
Both the RTC and IMU support deep sleep wakeup.
Pass a time value.
As for the IMU, you need to program its registers via the datasheet to generate a pulse via its interrupt pins, but the AE3 trigger is already armed to wake up from deep sleep.
